Does this thing learn?
cadillac ats forums cadillac ats forums
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 16
Like Tree1Likes
Cadillac ATS General Discussion Forum Discussion, Does this thing learn? in Cadillac ATS Discussion Forums; I have my Cadillac ATS performance for almost a month, and have put around 400 miles on it.... Today when ...
    ben.gators is online now Cadillac Owners Master
    Automobile(s): '14 ATS Premium with 3 pedals | Past: '13 ATS Performance & '99 Seville STS
    Aug 2009
    somewhere good!
    5,179
    I have my Cadillac ATS performance for almost a month, and have put around 400 miles on it.... Today when I drove her, it really felt different, it felt very alive compared to before! I have a heavy foot and drive spiritedly! Does this car really learn? I read here that the on-board computers monitor the drivers driving habits and adjust the settings accordingly! But I didn't think that it is going to be so different and obvious....
    I am happier than before, and I was happy at the beginning too!
    Hoosier Daddy's Avatar
    Hoosier Daddy is offline Super Moderator
    Automobile(s): 2013 ATS Performance 2.0T M6
    Feb 2013
    Winchestertonfieldville, AZ
    67
    6,011
    Re: Does this thing learn?
    Quote Originally Posted by ben.gators View Post
    Yes it does. But I don't think its a sudden thing. Maybe a combination of that and the best possible air temp, density and humidity.
    Aug 2009
    somewhere good!
    5,179
    It was holding the gears longer than before, and yes, the car was still in touring mode....
    Feb 2013
    67
    6,011
    Transmissions in some cars also learn.
    flycaster's Avatar
    flycaster is offline Cadillac Owners Enthusiast
    Automobile(s): 2013 ATS 2.0T AT Lux, 2017 MB C300 Coupe
    Mar 2013
    Boynton Beach, FL
    78
    910
    Well, since it appears to me that Caddy copied just about everything it could from the BMW 3-series (including such innocuous things as having to pull the inside door handle twice to open a locked door), they could have also copied BMW's ability to learn one's driving style. Don't know how it works, but I do know that on my 2002 325i and continuing onwards, through its Adaptive Transmission Management OBC program, the transmission is "trained" to adapt to your driving style as you drive the car (http://www.f30post.com/forums/showthread.php?t=694128).
    ben.gators likes this.
    glover is offline Cadillac Owners Member
    Feb 2012
    26
    Caddy transmissions have had adaptive functions since at least the mid 90's
    ATX_BLK_CTS is offline Cadillac Owners Member
    Automobile(s): CTS-V Coupe
    Feb 2013
    47
    9
    Did you have your shifter pushed to the left in sport mode? That will do exactly what you described. Hold gears longer, more agressive downshifts, etc.....
    Thunder Gray STS's Avatar
    Thunder Gray STS is offline Cadillac Owners Fanatic
    Automobile(s): 2013 ATS 2.0T Premium
    Jun 2009
    Memphis TN
    50
    236
    Quote Originally Posted by ATX_BLK_CTS
    I thought when you pushed it to the left it is in manual mode. Will it shift on its own?
    Aug 2009
    somewhere good!
    5,179
    Quote Originally Posted by ATX_BLK_CTS View Post
    When you push the shifter to left, it goes to manual mode. In manual mode the driver himself is supposed to shift using paddle shifter, if the car is equipped, or just by pushing the stick shifter itself forward or backward. However, in this mode the computer still monitors the shifting patterns and intervenes, if necessary, to protect the transmission and the engine! Examples:
    1-If you don't upshift and the engine RPM reaches to the redline, the car itself upshifts to protect the engine!
    2- You are reducing your speed, but you are not downshifting. In this case the car itself downshifts for you.
    3- Your speed is low and you are still accelerating and you want to upshift to a taller gear. In this case your shift command will be denied.
    I think you are referring to numbers 1 and 2 in this list! It doesn't hold gears longer and it is not the sport mode! The computer is just trying to protect the engine and the transmission from you!
    Quote Originally Posted by glover View Post
    My previous Cadillac was a '99 Seville STS, and it was equipped with Performance algorithm shifting, aka PAS. This system basically monitors the driver's driving patten, and if it decides the driver is driving very aggressively, the PAS kicks in. But it was very hard to get to that point and initiate the PAS system.
    But in my ATS, I feel it adapts itself even for everyday driving.
    pissedoffwookiee's Avatar
    pissedoffwookiee is offline Cadillac Owners Connoisseur
    Automobile(s): '16 CTS V-Sport Black/'16 CTS Luxury w/V-Sport Pkg White
    Mar 2013
    Carlsbad, CA
    3,801
    Quote Originally Posted by Thunder Gray STS View Post
    No, that is how Cadillac used to engage sport mode, but with ats they broke it out of the shifter and gave it a dedicated button, manual shift and sport mode was a source of some confusion with both being in the same position
    Aug 2009
    somewhere good!
    5,179
    Quote Originally Posted by pissedoffwookiee View Post
    Oh, I see! After reading your post I realized that ATX_BLK_CTS drives a CTS! I thought he was commenting about his ATS and how he drives it! Thanks God it was just a misunderstanding! Yes, as you said, it seems that the ATS is different from the CTS!
    Feb 2013
    47
    9
    Oops. I meant push to the right to sport mode.
    By putting it in sport mode (to the right) it starts in 1st gear which gives you faster starts, and also more aggressive shifts. Manually shifting in this mode is an option, but not mandatory. I much perfer the paddle shifters over the + - on the shifter.
    Caddi may have this engineered different on the ATS. Try and let us know.
    The sport mode button I mean......I drives much more livelyer. Happy driving ! Congrats on your ATS!
    Peyton is offline Cadillac Owners Member
    Automobile(s): 3.6 ATS Premium
    Jun 2013
    18
    FYI, VW has been doing the same with the door handles for at least 5 maybe 8 years. I've had 5 vws since 2001.
  16. #14
    Feb 2013
    67
    6,011
    Quote Originally Posted by Peyton View Post
    I can't believe they don't have a cure for that!
  17. #15
    Aug 2009
    somewhere good!
    5,179
    OK, I am lost....
  18. Remove Advertisements
