Disabling hill assist?
cadillac ats forums cadillac ats forums
Page 1 of 2 12 LastLast
Results 1 to 15 of 26
Like Tree5Likes
Cadillac ATS General Discussion Forum Discussion, Disabling hill assist? in Cadillac ATS Discussion Forums; dunno if this was mentioned or not, but I have a manual with no CUE and I cant for the ...
    Stevo Supremo's Avatar
    Stevo Supremo is offline Cadillac Owners Connoisseur
    Automobile(s): ATS RWD 2.0 Manual
    Feb 2013
    1,347
    dunno if this was mentioned or not, but I have a manual with no CUE and I cant for the life of me find out how to disable that STUPID hill assist. I looked through the owners book and found nothing (am I blind?)
    anyways, is there a fuse? I looked for that to and couldn't find one.
    roadpie4u is offline Cadillac Owners Enthusiast
    Automobile(s): ATS 2.0 M6 FE3
    Apr 2013
    Buffalo, NY
    558
    Re: Disabling hill assist?
    I know how Bendix's systems work and Ill assume these function on a similar principle - if so it is a function of the ABS controller/module and is thusly impossible to disable without removing the grade sensor (which would trigger a brake fault as it is used for rollover detection).
    Personally I don't mind it - I know plenty of Subaru/BMW guys (and truckers with class 8 trucks) that love the feature. Take the car to Seattle or San Fran and I think it'd be a godsend when you're tired.
    Feb 2013
    1,347
    Quote Originally Posted by roadpie4u View Post
    lol yeah I guess it would be a godsend on those grades, but I think the steepest grade around here is like... 25degrees? its just annoying having the brake clamp on the slightest incline, its just not necessary and drives me nuts lol
    73JPS is offline Cadillac Owners Fanatic
    Automobile(s): 2013 ATS 2.0T Performance 6MT
    Mar 2013
    Ontario, Canada
    270
    Quote Originally Posted by Stevo Supremo View Post
    I'm always amazed at how small the angle actually is on a road that looks like a huge hill: a 25 degree grade would exceed the slope of the steepest street in the United States. The street that tops the list here http://www.fixr.com/infographics/top...t-streets.html has a 45 per cent gradient, which would be an angle of around 23 degrees. An airplane on descent to a runway typically follows a 3 degree descent path, but most people on the ground watching one approach to landing will estimate the angle at much steeper than that.
    Izshint dat veird?
    ben.gators and danscrim like this.
    huna is offline Cadillac Owners Fanatic
    Automobile(s): ATS 3.6 AWD Premium Thunder Gray, Caramel, with peanuts
    Dec 2006
    107
    Quote Originally Posted by 73JPS View Post
    Izshint dat veird?
    I appreciate the topic. Indeed people (including me) usually overestimate how steep something is. One correction: 45% grade is 20.25 degrees.
    Mar 2013
    Ontario, Canada
    270
    Quote Originally Posted by huna View Post
    Could be, I didn't put too much thought into the calculation; however, I made the conversion from the chart on this page: http://en.wikipedia.org/wiki/Grade_%28slope%29
    Regardless, I tend to agree with Steve on the HillHolder: I'm not a big fan.
    Feb 2013
    1,347
    anyways, not to get into anything too deep about road construction or angles... I just want to get rid of that annoying wheel clamp whenever im on an incline lol.
    Feb 2013
    1,347
    just doing some looking, the camaro guys figured it out
    http://www.camaro5.com/forums/showthread.php?t=300649
    Hoosier Daddy's Avatar
    Hoosier Daddy is offline Super Moderator
    Automobile(s): 2013 ATS Performance 2.0T M6
    Feb 2013
    Winchestertonfieldville, AZ
    68
    6,101
    Good find for anyone wanting to permanently disable.
    Edit: Or maybe not. See below.
    roadpie4u likes this.
    Apr 2013
    Buffalo, NY
    558
    Strange... I figured removing the grade sensor would do it... but I can't believe GM made a "dummy" grade sensor for automatic cars instead of just omitting that whole layer of the harness...
    Well - good to know.
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,969
    doesn't look like that will work for you guys
    might be worth trying though
    reason i say so is that after looking at the camaro part numbers (for the MT vs AT yaw sensors) and then comparing to the ATS yaw sensor part number
    there is only one ATS yaw sensor for both AT and MT cars unlike the Camaro that has two
    so... the question then becomes can you use the camaro part number and will that talk nice with the rest of the ATS systems?
    i doubt it ... but again it might be worth someone trying just to find out for sure
    General Lee 01's Avatar
    General Lee 01 is offline Cadillac Owners Member
    Automobile(s): 2013 ATS 2.0T, MT, RWD, BNR TUNE, WHITE DIAMOND
    Jun 2013
    Northeast Ohio
    36
    What is so bad about the hill assist? I like it. This will also save wear and tear on the clutch over time.
    Jones atsnh likes this.
    Jones atsnh is offline Cadillac Owners Member
    Automobile(s): Ats 2.0t Premium
    Nov 2012
    50
    Also I've found that the softer you stop the less frequent the hill assist turns on. If you stop hard the hill assist activates, but if you barely come to a stop the hill assist doesn't grab.
  16. #14
    mikesul is offline Cadillac Owners Enthusiast
    Automobile(s): 16 2.0T Perf, 8spd auto, dp, E85, tune
    Aug 2010
    S FL
    811
    It does seem to take a little extra pressure on the brake pedal to activate it on my car. Soft touch, no clamp effect.
  17. #15
    Nov 2012
    50
    Quote Originally Posted by mikesul View Post
    Exactly.
  18. Remove Advertisements
