Low Brake Fluid and Service Stabilitrak Light
cadillac ats forums cadillac ats forums
Results 1 to 6 of 6
Cadillac ATS General Discussion Forum Discussion, Low Brake Fluid and Service Stabilitrak Light in Cadillac ATS Discussion Forums; Morning all, Anyone had this warning come on? Low Brake Fluid Service Stabilitrak Mine came on (on and off) this ...
    morphius909 is offline Cadillac Owners Member
    May 2013
    42
    13
    Morning all,
    Low Brake Fluid
    Service Stabilitrak
    Mine came on (on and off) this weekend. Calling Service Dept this morning.
    Hoosier Daddy's Avatar
    Hoosier Daddy is offline Super Moderator
    Automobile(s): 2013 ATS Performance 2.0T M6
    Feb 2013
    Winchestertonfieldville, AZ
    68
    6,085
    Re: Low Brake Fluid and Service Stabilitrak Light
    Was your brake fluid low?
    Cadillac Cust Svc's Avatar
    Mar 2010
    Detroit, USA
    12,711
    Quote Originally Posted by morphius909 View Post
    Morning all,
    Low Brake Fluid
    Service Stabilitrak
    Hello morphius909,
    Were you able to discuss this concern with the service department yet? Just wondering if you have a new update on your concern or not. I can also be contacted via private message if you would like to discuss any concern further or have additional questions.
    Laura M.
    Cadillac Customer Care
    May 2013
    42
    13
    Checked the fluid and it was SEVERELY low. Below the MIN mark. Added some from Canadian Tire. No more warning light.
    Car goes in on Friday morning as that is not normal by any means. I did not notice any leaks, drops, or fluid anywhere.
    Feb 2013
    68
    6,085
    Since you didn't check the level when you started the thread I'm guessing you probably didn't check it when taking delivery. If that's the case, and you don't see leaks, it was probably never filled. Dealers are supposed to check things but they are human. Some will forget, some will cut corners.
    C&C's Avatar
    C&C
    C&C is offline Cadillac Owners Connoisseur
    Automobile(s): Cadillac XT5 (2017)
    Feb 2008
    Mount Pleasant, SC
    66
    1,961
    Worn brake pads can lower you brake fluid level. As your car is fairly new, it doesn't seem likely (but until it gets checked out you never know); best of luck with your diagnosis (and repair).
  9. Remove Advertisements
