cadillac ats forums cadillac ats forums
Results 1 to 2 of 2
Thread: DTS compatable disks and other audio
    TonyT's Avatar
    TonyT is offline Cadillac Owners Fanatic
    Automobile(s): 2014 ATS
    May 2004
    North Andover, MA.
    68
    111
    I have a bunch of DTS 5.1 compatible disks that use to play perfectly in my 2008 CTS none of which will play in my 2014 ATS premium with upgraded sound system, all I get is static.
    Also I copied all my music from my computer to a mini USB drive which works perfectly, I copied exactly the same files to an SD card (fat32) and only the first song will play when you select next sound from the steering wheel control it reverts back to the first song.
    Any clues for either problem ?
    Hoosier Daddy's Avatar
    Hoosier Daddy is offline Super Moderator
    Automobile(s): 2013 ATS Performance 2.0T M6
    Feb 2013
    Winchestertonfieldville, AZ
    68
    6,083
    Re: DTS compatable disks and other audio
    Quote Originally Posted by TonyT View Post
    FWIW:
    Based on other posts, the ATS won't play that format disk.
    My 32GB SD card is formatted in NTFS. So I don't know why your SD doesn't work right. I guess it could be a bug, or ATS doesn't like FAT or something else.
  • You may not post replies
