Voice command soliloquy
cadillac ats forums cadillac ats forums
Results 1 to 10 of 10
Cadillac ATS General Discussion Forum Discussion, Voice command soliloquy in Cadillac ATS Discussion Forums; Whenever I push the voice command button on the steering wheel, I get a response "a device is initializing, the ...
    sd vidiot is offline Cadillac Owners Member
    Automobile(s): 2013 ATS 2.0T Premium RWD 6M
    Mar 2013
    54
    23
    Whenever I push the voice command button on the steering wheel, I get a response "a device is initializing, the device is unavailable while initializing" or some such. It then allows me to make my call. This happens every time even when I have been in the car for a while and presumably everything has initialized. I have an iPod attached to the USB port in the magic storage bin. This prompt occurs whether or not the iPod is attached or even if I've been using the iPod.
    Is this normal? Anyway to turn this off?
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,986
    Re: Voice command soliloquy
    have you had the CUE update done to your car yet?
    i know that this was one of the bugs that was worked out
    unless of course you are running into some other bug or limitation causing your device to not initialize
    if you have had the CUE update try calling the CUE helpline 855-4CUE-NOW
    Mar 2013
    54
    23
    My car was built in May, so I assume it has the latest and greatest software.
  5. #4
    Sep 2007
    Wilmington, NC
    13,986
    hmm... then call the CUE hotline
  6. #5
    Mar 2013
    54
    23
    Good to know I"m not crazy. I will follow up with them. Thanks!
  7. #6
    AtlantaGuy00 is offline Cadillac Owners Fanatic
    Automobile(s): 2007 DTS, 2013 ATS
    Jun 2012
    50
    313
    I've had the update and it does that to me a lot. I also wish there was a "beep only" setting so that every time I press the button, particularly for the Nav system it doesn't read the owners manual to me. If you can make it do that, someone let me know where the setting is.
  8. #7
    frankc5r is offline Cadillac Owners Fanatic
    Automobile(s): 2.0 ATS Premium
    Aug 2007
    SE Michigan
    226
    Quote Originally Posted by AtlantaGuy00 View Post
    I had the update and there was a fix. I was upset that is was always repeating info I knew and I told an advisor I wish you could just hit the button when she was talking to shut her up and let u do your command. Turns out that WAS done. Now when hit the button the first timeand say navigation and she starts the long explanation, I just hit button 2nd time, she shuts up and there is a beep. Works great. Must however not just push button 2nd time and talk. Wait for beep.
  9. #8
    73JPS is offline Cadillac Owners Fanatic
    Automobile(s): 2013 ATS 2.0T Performance 6MT
    Mar 2013
    Ontario, Canada
    270
    I think the best you can do on this one is Settings > Voice > Prompt Length, and select "short prompt" or some such; no "beep only" that i am aware of, but like you I would probably prefer it.
  10. #9
    pissedoffwookiee's Avatar
    pissedoffwookiee is offline Cadillac Owners Connoisseur
    Automobile(s): '16 CTS V-Sport Black/'16 CTS Luxury w/V-Sport Pkg White
    Mar 2013
    Carlsbad, CA
    3,714
    Quote Originally Posted by 73JPS View Post
    doesn't work, because the short promt option reverts back to long after a start or two
  11. #10
    flycaster's Avatar
    flycaster is offline Cadillac Owners Enthusiast
    Automobile(s): 2013 ATS 2.0T AT Lux, 2017 MB C300 Coupe
    Mar 2013
    Boynton Beach, FL
    78
    908
    Quote Originally Posted by pissedoffwookiee View Post
    Correcto. My "short" instructions don't hold, either...and I've had the update.
    Good news on hitting the button the second time to cut her off at the pass...
  12. Remove Advertisements
