How to shift out of Park with engine not running?
cadillac ats forums cadillac ats forums
Results 1 to 15 of 15
Like Tree4Likes
  • 4 Post By Vernon Cooke
Cadillac ATS General Discussion Forum Discussion, How to shift out of Park with engine not running? in Cadillac ATS Discussion Forums; Just curious, but is it possible to shift the automatic transmission out of Park and into neutral if the engine ...
    Vernon Cooke is offline Cadillac Owners Member
    Automobile(s): 2013 2.5 ATS
    Mar 2013
    33
    Just curious, but is it possible to shift the automatic transmission out of Park and into neutral if the engine won't start?
    This seems like an obvious requirement to move a stranded vehicle.
    MASCAD is offline Cadillac Owners Member
    Automobile(s): ATS4 3.6 2013; CTS-V COUPE 2011
    Jun 2009
    NORTHERN NEW YORK
    79
    Re: How to shift out of Park with engine not running?
    As per section 9 in the owners manual:
    This vehicle is equipped with an
    electronic shift lock release system.
    The shift lock release is designed to
    prevent movement of the shift lever
    out of P (Park), unless the ignition is
    in ON/RUN or ACC/ACCESSORY
    and the brake pedal is applied.
    The shift lock release is always
    functional except in the case of an
    uncharged or low voltage (less than
    9 volt) battery.
    If the vehicle has an uncharged
    battery or a battery with low voltage,
    try charging or jump starting the
    battery. See Jump Starting on
    page 10‑73.
    Bertha D Blues Guest
    So, you disconnect the battery and then shift to neutral?
    Jun 2009
    NORTHERN NEW YORK
    79
    Quote Originally Posted by Bertha D Blues View Post
    What they are saying that since the device is electrical, you must have the battery connected (and charged) to get it out of park. Once that is accomplished, the battery can be disconnected if you want.
    Dave3283's Avatar
    Dave3283 is offline Cadillac Owners Fanatic
    Automobile(s): ATS, 2.0t - Performance
    Jan 2013
    Ontario, Canada
    232
    Why do you have to shift it out of park to change the battery?
    Quote Originally Posted by MASCAD View Post
    Got it. I misunderstood when I first read that. The manual also states on page 9-22 "Turn the ignition to ON/RUN or
    ACC/ACCESSORY" to shift out of park. I tried this with ACC on (engine off) but that didn't work. Bert
    Mar 2013
    33
    Section 9 of the manual is correct, but also assumes the engine is running. My ATS is locked in Park without a running motor. Dealer has not been much help.
    Jun 2009
    NORTHERN NEW YORK
    79
    Quote Originally Posted by Vernon Cooke View Post
    I"ll have to try this on the ATS but on my '11 CTS this procedure does work even if the engine isn't running. The write up in both manuals is exactly the same BTW.
    Jun 2009
    NORTHERN NEW YORK
    79
    You are absolutely correct; this procedure does not work in the ATS like it does in the CTS. The wording in both manuals is exactly the same and states that the shift lock release is always functional except in the case of an uncharged or low voltage battery. It does not say anything about the engine running and in fact implies that it doesn’t have to be since it states it will work in the ACC/ ACCESSORY position. Is it possible to get to that position with the engine running.??? I kind of think that it is intended to work without the engine running since as the OP stated how could a stranded vehicle be moved? It looks like maybe there is something missing in the software for one of the control modules.
    Has the dealer managed to get yours out of park yet?
    M5eater's Avatar
    M5eater is offline Cadillac Owners Connoisseur
    Automobile(s): ATS 2.0T RWD FE3
    May 2011
    Suffolk, VA
    29
    4,561
    That would be...annoying.
    Mar 2013
    33
    I contacted Cadillac headquarters about this shift into neutral issue. Working with my dealer, they figured it out.
    Press the Engine Start/Stop button until button illumination changes to green (about 10 seconds).
    Release the button. Then press the brake and the transmission will shift out of neutral.
    Cadillac says the procedure will be included in future manuals.
    Jun 2009
    NORTHERN NEW YORK
    79
    Very good detective work. Looks like they just carried over the CTS proccedure to the ATS manual without actually testing it to see if it worked.
    ontogenesis is offline Cadillac Owners Fanatic
    Automobile(s): 2012 SRX 3.6, 2013 ATS 2.0T
    May 2013
    Florida Panhandle
    129
    Good information to have, thanks Vernon for tracking down this procedure!
  16. #14
    73JPS is offline Cadillac Owners Fanatic
    Automobile(s): 2013 ATS 2.0T Performance 6MT
    Mar 2013
    Ontario, Canada
    270
    It's possible they have done lots of cut-and-paste with this Owner's Manual: it certainly isn't a very good document.
    I am glad to see that the "shift out of park with the engine not running" mystery has been resolved though: interesting stuff.
  17. #15
    M5eater's Avatar
    May 2011
    Suffolk, VA
    29
    4,561
    Thanks a lot of that, I found myself ironicly comming back to my post, and this thread when I wanted to move the car a few inches up in the garage.
  18. Remove Advertisements
