Another article on the 2014
cadillac ats forums cadillac ats forums
Results 1 to 10 of 10
Cadillac ATS General Discussion Forum Discussion, Another article on the 2014 in Cadillac ATS Discussion Forums; Another article on the 2014: http://www.conceptcarz.com/z22816/Cadillac-ATS.aspx It lists an additional color: Mocha Steel Metalic in addition to the Phantom Gray, ...
    Hoosier Daddy's Avatar
    Hoosier Daddy is offline Super Moderator
    Automobile(s): 2013 ATS Performance 2.0T M6
    Feb 2013
    Winchestertonfieldville, AZ
    67
    6,039
    It lists an additional color: Mocha Steel Metalic in addition to the Phantom Gray, Red Obsession and Majestic Plumb mentioned previously.
    AtlantaGuy00 is offline Cadillac Owners Fanatic
    Automobile(s): 2007 DTS, 2013 ATS
    Jun 2012
    50
    313
    Re: Another article on the 2014
    Cant wait to see the new colors. I wonder if all the bugs will be worked completely out (heater noise, creepy drivers seat).
    DG2's Avatar
    DG2
    DG2 is offline Cadillac Owners Connoisseur
    Jul 2004
    1,703
    Quote Originally Posted by AtlantaGuy00
    I'm sure they will be. The new GM policy is to sweep in and fix problems flaws ASAP vs the old way of defending the flaws etc. lots if press on this yesterday as they fixed major design cues on the new Malibu in just a year !! That's awesome
    amunderdog is offline Cadillac Owners Connoisseur
    Automobile(s): 1994 SLS x 2 ---- 1993 Eldorado Sport ----- 1994 Deville 4.9
    Feb 2010
    Sunbright, TN
    1,530
    M5eater's Avatar
    M5eater is offline Cadillac Owners Connoisseur
    Automobile(s): ATS 2.0T RWD FE3
    May 2011
    Suffolk, VA
    29
    4,561
    Quote Originally Posted by AtlantaGuy00 View Post
    I wouldn't get overly excited. I bet the 'new' colors are the same as the old, just renamed.
    and just so we know.
    this is a 'frameless' review mirror. I love it. It's exceptionally classy
    Feb 2013
    67
    6,039
    Quote Originally Posted by M5eater View Post
    The red is very close. The Gray is more of a change. The others are completely new, at least to the ATS. But I'm pretty underwhelmed. I was disappointed in 2013 with only one non-metallic and not even a white (not counting the metal-flake one that isn't even white anyway). Still no white or other non-metallics. But Mocha Steel is much better than the Gold it replaces. The plumb will probably be more popular than the light blue it replaces, so things are probably a little better for 2014.
    M5eater's Avatar
    May 2011
    Suffolk, VA
    29
    4,561
    Quote Originally Posted by Hoosier Daddy View Post
    I haven't seen these colors even on the net. unless I've missed them, can you link?
    Feb 2013
    67
    6,039
    Sure I posted some in another thread.
    There are several sites showing small color chips. Here is one that also shows them on a small picture of a 2014 ATS:
    http://www.autoguide.com/new-cars/20...wd/prices.html
    It doesn't show the Mocha Steel but that is a common color on other Cadillac models and other GM brands so you can just Google it.
    like2drive's Avatar
    like2drive is offline Cadillac Owners Fanatic
    Automobile(s): 09 CTS RWD 3.6L SFI Black Cherry / Cashmere
    Jan 2008
    Southern CT
    38
    388
    In the article referenced in the OP, one can read:
    "Low vehicle mass and optimal brake sizes give the ATS braking performance that is among the best in the §egmènt, wîth Brembo brakes contributing to 60-0 performance of approximately 129 feet (39.3 meters)."
    I just hope that this is a mistyping because 129ft to fully stop 60-0 is not at all impressive! I guess such a car should be able to stop within 110ft. Just my 2 cents.
    M5eater's Avatar
    May 2011
    Suffolk, VA
    29
    4,561
    Quote Originally Posted by like2drive View Post
    100% a mistype.
    it's closer to 108ft. -110ft
  13. Remove Advertisements
