Heads-up on SD armrest port malfunction.
cadillac ats forums cadillac ats forums
Results 1 to 3 of 3
Cadillac ATS General Discussion Forum Discussion, Heads-up on SD armrest port malfunction. in Cadillac ATS Discussion Forums; Had this happen recently and thought you might be interested. I've been using an iTunes-loaded SD card and redid the ...
    flycaster's Avatar
    flycaster is offline Cadillac Owners Enthusiast
    Automobile(s): 2013 ATS 2.0T AT Lux, 2017 MB C300 Coupe
    Mar 2013
    Boynton Beach, FL
    78
    916
    I've been using an iTunes-loaded SD card and redid the card. When replacing it into the port, the card met no resistance and almost totally slipped into the port. Took problem to the dealer, who fixed it. Here's what happened to the port: The unit behind the port is a "snap-together" unit. Apparently it wasn't snapped together too well and it fell away from its supports and in doing so, just wasn't behind the port opening anymore.
    Stevo Supremo's Avatar
    Stevo Supremo is offline Cadillac Owners Connoisseur
    Automobile(s): ATS RWD 2.0 Manual
    Feb 2013
    1,347
    Re: Heads-up on SD armrest port malfunction.
    weird, thanks for the heads up though! only issue I've had with this is intermittent failure to read device.
    flycaster's Avatar
    Mar 2013
    Boynton Beach, FL
    78
    916
    Quote Originally Posted by Stevo Supremo View Post
    weird, thanks for the heads up though!:thumbs up: only issue I've had with this is intermittent failure to read device.
    You're welcome. BTW, I haven't had your problem. CUE works the SD perfectly (Playlists, Genre, Artists).
