Valentine V1 hardwire
cadillac ats forums cadillac ats forums
Results 1 to 4 of 4
Cadillac ATS General Discussion Forum Discussion, Valentine V1 hardwire in Cadillac ATS Discussion Forums; Want to hardwire my Valentine V1. Saw there is a fuse panel on the drivers side of the dash. Many ...
    sdm100 is offline Cadillac Owners Member
    Automobile(s): ATS
    Apr 2013
    19
    Want to hardwire my Valentine V1. Saw there is a fuse panel on the drivers side of the dash. Many of the fuse locations are not used. Question is are they hot and can one insert a fuse in an unused location and get the power needed or do i have to tap one of the exisitng used fuses. Really easy location to use as I can run the wire right down the drivers side pilar to the box. Appreciate the help
    mikesul is offline Cadillac Owners Enthusiast
    Automobile(s): 16 2.0T Perf, 8spd auto, dp, E85, tune
    Aug 2010
    S FL
    808
    Re: Valentine V1 hardwire
    Check search as this has been discussed, pictures available in the answers.
    flycaster's Avatar
    flycaster is offline Cadillac Owners Enthusiast
    Automobile(s): 2013 ATS 2.0T AT Lux, 2017 MB C300 Coupe
    Mar 2013
    Boynton Beach, FL
    78
    910
    Here you go: Fuses 17 and 18, power flows on/off with ignition on/off. Take a look at this thread for info and pics: http://www.cadillacforums.com/forums...where-diy.html
    When I did it, my only concern was that the wire would be difficult to squeeze between the dash and the pillar. This concern turned out to be a no-brainer. Just push the wire in using a flat tool...really easy. Good luck.
    thebigjimsho's Avatar
    Automobile(s): ZIP
    In the barrel of a gun...
    51,885
    In my Vs, I just tapped into the dome light. Never an issue.
  7. Remove Advertisements
