Need seating advice before I get a divorse-Thank you Caddy, I didn't need this! - Page 2
cadillac ats forums cadillac ats forums
Results 16 to 30 of 38
Like Tree1Likes
Cadillac ATS General Discussion Forum Discussion, Need seating advice before I get a divorse-Thank you Caddy, I didn't need this! in Cadillac ATS Discussion Forums; If I understand correctly, the seats functioned properly prior to the upgrade to 23150273 but not after? ----------...
  1. #16
    MASCAD is offline Cadillac Owners Member
    Automobile(s): ATS4 3.6 2013; CTS-V COUPE 2011
    Jun 2009
    NORTHERN NEW YORK
    79
    Re: Need seating advice before I get a divorse-Thank you Caddy, I didn't need this!
  2. #17
    flycaster's Avatar
    flycaster is offline Cadillac Owners Enthusiast
    Automobile(s): 2013 ATS 2.0T AT Lux, 2017 MB C300 Coupe
    Mar 2013
    Boynton Beach, FL
    78
    910
    As far as I know, that is correct. But it's not that they don't function now, it's just that they don't fully function as they used to. Stuff was taken away during the updating.
  3. #18
    rustybear3's Avatar
    rustybear3 is offline Cadillac Owners Connoisseur
    Automobile(s): 2013 ATS White Pearl Turbo
    Feb 2012
    Ohio
    65
    1,659
    You must be an isolated situation. My seats and FOBS work just fine for personalization. Go to a different dealer, and get your seats fixed or CUE reloaded.
  5. #19
    flycaster's Avatar
    Mar 2013
    Boynton Beach, FL
    78
    910
    Quote Originally Posted by rustybear3 View Post
    Do your seats work as I have described they should work: Each fob will seat its individual seat position when entering or turning car on, regardless of who drove last. Also, what is your version is your update?
  6. #20
    USe-car is offline Cadillac Owners Member
    Automobile(s): 2013 ATS & 2012 Volt
    Mar 2013
    Georgetown, TX
    68
    But, how do you tell the key fobs apart? Please, somebody tell me.
  7. #21
    rchern is offline Cadillac Owners Fanatic
    Automobile(s): 2012 Crystal Red CTS Coupe with Ebony Interior
    Dec 2006
    Mount Kisco,NY
    448
    Quote Originally Posted by USe-car View Post
    My fobs have numbers on the bottom (the non key ring side). I'm the only person that drives my car so the fob I use is getting tough to read because the numbers are printed on and it's wearing off but the other one is pretty easy to see, but the numbers are pretty small. I don't have an ATS, I have a CTS and I don't know if we have the same fobs but I imagine the numbers are there on yours
  8. #22
    rustybear3's Avatar
    Feb 2012
    Ohio
    65
    1,659
    Quote Originally Posted by flycaster View Post
    The FOBS work fine and retain their individual seating options. I have no idea what the upgrade number is.
  9. #23
    flycaster's Avatar
    Mar 2013
    Boynton Beach, FL
    78
    910
    When you say they maintain their individual seating positions, is that so after driver one gets out and locks the car (leaving his seat position set in his position) and then driver two unlocks the car and the seat moves into his position (either when door opens or when ignition goes on, according to how you set up automatic seat positioning) without his touching anything?
    To get your version number go to Home Page>Settings>Software Info. If you get 23150273 as your version number, then you will have had the upgrade
    So, if your seats behave as I have described, and your version number is 23160273, then you are very lucky that the update didn't take away one of the automatic seating possibilities. If your version is not that, then you can expect your automatic seating positioning to work for both fobs.
  10. #24
    rustybear3's Avatar
    Feb 2012
    Ohio
    65
    1,659
    I have the 23180276 upgrade. I don't believe the CUE upgrade has anything to do with your problem. Probably a glitch occurred. Take it back to the dealer.
  11. #25
    flycaster's Avatar
    Mar 2013
    Boynton Beach, FL
    78
    910
    Interesting that you have a different update version??? Nonetheless, I was told by the CUE helpline that after the upgrade only one seat could be set automatically. Also, another change that you can checkout is that when you enter the car, you can no longer expect the seats to move fully by just tapping the seat button if the engine is not on...you have to hold it until it reaches its full position. However, if the engine is on, tapping the buttons will move the seats fully. I was also told that the reason for this was that older folks (who probably shouldn't be driving, and who are probably the reason for other ridiculous CUE changes because Caddy felt that older folks just couldn't figure out what CUE was all about, and there would be a loss of sales to this older market segment) we getting squashed by the automatic movement??? So, Caddy out of fear of being sued, deleted the automatic seat position movement button function.
  12. #26
    torkibe is offline Cadillac Owners Fanatic
    Automobile(s): 2013 ATS 3.6
    Mar 2013
    153
    Well, unless Caddy is counting down instead of up with their updates, you have a later version. Maybe they corrected something. I have the same version as Flycaster but haven't really tested his issues. I would be curious to get a later update though, as I definitely have some bugs in mine.
  13. #27
    Fraggy's Avatar
    Fraggy is offline Cadillac Owners Enthusiast
    Aug 2012
    914
    Quote Originally Posted by rchern
    There is no number on mine.
  14. #28
    rustybear3's Avatar
    Feb 2012
    Ohio
    65
    1,659
    Quote Originally Posted by torkibe View Post
    You may be right...You guys both definitely have an earlier update....the update I have has been glitch free....
  15. #29
    flycaster's Avatar
    Mar 2013
    Boynton Beach, FL
    78
    910
    AND THE ANSWER IS...The seat module has to be re-programmed.
    This is all very interesting. I spoke to CUE a while back and was told that only one automatic seat setting would be available after the update; whereas after speaking to them today, I learned that their first response was partially correct (the first CUE responder probably didn't know the full answer). After the update, the seat module has to be re-programmed in order to have automatic seat setting for both fobs when either opening the door or when starting the ignition. Thus, those that do have full automatic function of their seats after the update, most likely had their seat modules reprogrammed.
    The CUE folks have called my dealer, told them about my problem, how it is to be solved, and made an appointment for me. Hopefully, this Friday will solve the mystery.
    There was a tech bulletin sent out about this problem, so the dealers should be aware of it. It goes something like this (couldn't quite read my squiggly writing):
    "Seat memory ??? module reprogram service update, revised user manual supplement for ATS vehicle, only"
    Perhaps this solution should be made in a "Solved" thread?
  16. #30
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,986
    good
    this is exactly why I suggested that you call them back
    other forum members have also reported seat/memory issues after the update and that they had to get the module reprogrammed
    i think most of those were XTS owners but the systems are so similar it probably doesn't matter
    i'm pretty sure that it's due to the tech not doing the update correctly (or not checking everything fully after doing the software update)
  17. Remove Advertisements
