Moldy AC - opinions please - Page 8
cadillac ats forums cadillac ats forums
Page 8 of 26 FirstFirst 123456789101112131415161718 ... LastLast
Results 106 to 120 of 382
Like Tree53Likes
Cadillac ATS General Discussion Forum Discussion, Moldy AC - opinions please in Cadillac ATS Discussion Forums; Originally Posted by GJB So what has changed AC in cars have benn around for 5O years. This is the ...
  1. #106
    Hoosier Daddy's Avatar
    Hoosier Daddy is offline Super Moderator
    Automobile(s): 2013 ATS Performance 2.0T M6
    Feb 2013
    Winchestertonfieldville, AZ
    68
    6,085
    Re: Moldy AC - opinions please
    Quote Originally Posted by GJB View Post
    So what has changed AC in cars have benn around for 5O years. This is the first car out of 15 thathas had this issue?
    But the execution (actual part design) is going to be different between cars. I thought at least some of these problems are due to a drain hose being installed wrong causing water to stand instead of drain. I wouldn't be surprised if all of this was caused by that. The fact is manufacturers are perfectly happy to use a mask-the-problem fix if its cheaper than the proper fix. I'm not saying its the case, but if its dirt cheap to reprogram some after-blow than replace or move a hose that's buried and if that gets rid of x% of the complaints, they would do that.
    GJB likes this.
  2. #107
    probee773 is offline Cadillac Owners Fanatic
    Automobile(s): 2016 ATS 2.0T auto
    Jan 2013
    Sarasota, FL
    135
    So, my dealer says that they cannot turn on afterblow in my car because my car doesn't have this option (base 2.0T, auto + CUE). Isn't this just a software update? Do I need to find another dealer?
  3. #108
    GJB's Avatar
    GJB
    GJB is offline Cadillac Owners Connoisseur
    Automobile(s): 2013 ATS4 3.6 Premium Build Date 12/21/2012
    May 2013
    Northern VA
    1,608
    Look at poat#98 and ask your dealer about the Scan tool and bring that info with you.
  5. #109
    DEVGRU is offline Cadillac Owners Member
    Automobile(s): 2013 Cadillic ATS (Luxury)
    Apr 2014
    34
    19
    Just another update: It has been some time since I did the repair I posted. I still have fresh air in my car and the car is still draining condensation from the bottom of the car like it should. If anyone else has done the ac repair following the steps I provided, please feel free to post it. I'd like to know if you had success like I did. Thanks!
    DEVGRU
  6. #110
    GTO to ATS is offline Cadillac Owners Member
    Automobile(s): '13 ATS4 3.6
    Jun 2014
    32
    Did anyone take theirs in to the dealer and after they deorderize it have the car faintly smells like the musty smell at all times, not just the first 10 seconds the AC is on? Its no where near as strong as what it smelt like in those first 10 seconds (it doesnt get worse upon first turning on the AC) but its still noticeable...even when the car is off.
  7. #111
    Jan 2013
    Sarasota, FL
    135
    Quote Originally Posted by probee773 View Post
    Ok, so my ATS falls in this weird gap where the after-blow feature wasn't installed from the factory. See the article on the bottom left of page 6 of this link: http://sandyblogs.com/techlink/wp-co...ink-2013-F.pdf. My dealer followed these instructions, and now, I have after-blow! Let's hope this helps the issue (even a little) especially since I live in Florida, and it's starting to get hot and humid down here. ;-)
  8. #112
    GJB's Avatar
    GJB
    May 2013
    Northern VA
    1,608
    Took my ATS back to dealer for the musty odor because after blow did not correct the problem. Ticket states they repositioned drain tube and coated evaperator coil with cooling coil coating per PI1160A. Sure hope this fixes it.
    Does anyone know what cooling coil coating is?
    Silver 2012 CTS likes this.
  9. #113
    CTSCHICK Guest
    It is an acrylic based coating that is supposed to prevent airborne and moisture based bacteria, mold & mildew from building up on or sticking to the cooling coil preventing odor.
  10. #114
    GJB's Avatar
    GJB
    May 2013
    Northern VA
    1,608
    Quote Originally Posted by CTSCHICK View Post
    Which makes a lot of sense. I wonder why its not applied prior or during the build.
  11. #115
    rsingl's Avatar
    rsingl is online now Cadillac Owners Enthusiast
    Automobile(s): 2014 ATS 3.6 Premium RWD, 2016 Corvette Z06
    Sep 2007
    901
    I wonder how much the coating interferes with heat transfer to the coil? Maybe the effect is offset by reduced debris buildup on the coil/fins.
  12. #116
    GJB's Avatar
    GJB
    May 2013
    Northern VA
    1,608
    According to a manufacturer no interference. Check out this link very informative and It looks like they may make the AC DELCO version of this. http://www.airsept.com/index.php?loadmod=cccfaq
  13. #117
    Bertha D Blues Guest
    Does the service receipt note how long the repair took? I’m curious whether they removed your dash or dropped the trans or some other invasive tactic. Mine is going in soon for a recall and this is on my list. Bert
  14. #118
    GJB's Avatar
    GJB
    May 2013
    Northern VA
    1,608
    I'll look and let you know. I doubt they removed the dash it was only there 1.5 days and I had an alignment and recall inspection during the visit. I believe they went through the glove compartment to spray the coating (glove box and passenger seat had some minor grease/dirt marks from the tech). And in this post someone did the cleaning/coating themselves and they said you could at least see the drain from where that shifter cable runs so maybe they could reach it? Fly states they dropped the trans on his. Car was taken for a 10 Mile test drive after so they very well may have.
    Update: Asked SA and she said "He had to go under the dash and pull the side panel off to gain access to the evaporator"
    This seems to apply to adding the coating but doess not jive with anything else I've read on the drain tupe issue, so not too confident
    Update day 2 and still OK!
    Bertha D Blues likes this.
  15. #119
    CTSCHICK Guest
    That is the OEM, GM relabels and use's quite a few of their products.
    GJB likes this.
  16. #120
    GJB's Avatar
    GJB
    May 2013
    Northern VA
    1,608
    Quote Originally Posted by Bertha D Blues View Post
    Bert From my ticket it looks like time is listed as units and 1.10 was next to the AC fix and .90 for the recall work.
  17. Remove Advertisements
