Trembling at idle - Page 9
cadillac ats forums cadillac ats forums
Page 9 of 35 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 ... LastLast
Results 121 to 135 of 519
Like Tree39Likes
Cadillac ATS General Discussion Forum Discussion, Trembling at idle in Cadillac ATS Discussion Forums; Mine did too on my first tank from GM 87. No vibration using 94 only...
  1. #121
    Siren05's Avatar
    Siren05 is offline Cadillac Owners Fanatic
    Automobile(s): 2013 ATS 2.0T RWD. 2011 STI Hatchback.
    Mar 2013
    41
    293
    Re: Trembling at idle
  2. #122
    cathycpc is offline Cadillac Owners Member
    Automobile(s): ATS
    May 2013
    9
    Hi Gregory W,
    I've tried twice to private message you and Laura, but it won't let me.. Here is what they did. 5334 ECM out of calibration DIAG 0.00 scanned vehicle systems with GDS2 and found no codes. Scanned each module calibration via SPS and found a newly released update to improve idle quality. Programmed ECM and performed set-up to install new calibration. I'll se if this fixes it. So far so good. Will keep you updated.
    Cathy CPC
  3. #123
    bravnik is offline Cadillac Owners Fanatic
    Automobile(s): ATS 2.0T Premium, Raven/Murano, Sunroof, CAP
    Mar 2013
    193
    Did this new update fix the idle issue?
  5. #124
    Automobile(s): ATS
    May 2013
    9
    Too early to tell. So far so good. We'll see what happens in the days to come.
    Cathy CPC
  6. #125
    probee773 is offline Cadillac Owners Fanatic
    Automobile(s): 2016 ATS 2.0T auto
    Jan 2013
    Sarasota, FL
    135
    Cathycpc, any updates?
  7. #126
    Automobile(s): ATS
    May 2013
    9
    It has only been a week since it was in the shop, but so far so good. However, ever time is has been in, it has taken a few weeks for the problem to return.
    Cathycpc
  8. #127
    Mar 2013
    193
    Do you notice anything else from the new update? Like better/worse MPG or higher idle. Maybe more power better acceleration?
  9. #128
    Automobile(s): ATS
    May 2013
    9
    Haven't noticed anything different yet.
  10. #129
    Jan 2013
    Sarasota, FL
    135
    Cathycpc - thanks for the info. I provided my dealer with exactly what you said and they were able to update my ECM software (and QUE software).
    I'll keep everyone posted if this helped or not...
  11. #130
    JCip is offline Cadillac Owners Member
    Automobile(s): ATS
    May 2013
    This may have something to do with the software (programmer for over 40 years). When designing a large program, the software has to go through a loop for the constant rechecking of all the systems that it is designed to monitor. If there are a number of subprograms that the program must check and recheck, then there will be a delay. This delay may be what is causing this idle problem. Therefore, if it takes a bit of time to check the operation of the engine at low RPMs, a stall may start. So, if this number drops below 800 rpms then performance can suffer while the program resets the engine operation. I have had this problem too.
  12. #131
    Dave623 is offline Cadillac Owners Member
    Automobile(s): ATS 2.5 Glacier Blue
    Feb 2013
    36
    Just asked my dealer's service manager about the update for idle calibration. He says it is only for the 6 cylinder and not the
    2.0t or the 2.5 engines. Can anyone confirm this? I've been putting up with the tremble for nearly 6 months.
  13. #132
    Automobile(s): ATS
    May 2013
    9
    Mine is a 2.0tT and they did the up date on it. Not sure if this fixed it. Only time will tell.
  14. #133
    Feb 2013
    36
    @cathycpc -- thanks for the info. My dealer hasn't exactly been a wealth of knowledge when it comes to the ATS.
  15. #134
    myronf is offline Cadillac Owners Member
    Automobile(s): 2013 ATS 2.0 turbo black/black
    Oct 2007
    WI
    32
    Seems like the trembling at idle reports are going away. Has the problem been solved?
  16. #135
    Stevo Supremo's Avatar
    Stevo Supremo is offline Cadillac Owners Connoisseur
    Automobile(s): ATS RWD 2.0 Manual
    Feb 2013
    1,347
    after i put my intake on the trembling has substantially decreased, its not fully disappeared, but its decreased by a lot.
    I know though for a fact that some tremble is a result of direct injection, Toyota now has a system that uses DI and PI that reduce tremble.
  17. Remove Advertisements
