Trembling at idle - Page 26
cadillac ats forums cadillac ats forums
Page 26 of 35 FirstFirst ... 1617181920212223242526272829303132333435 LastLast
Results 376 to 390 of 519
Like Tree39Likes
Cadillac ATS General Discussion Forum Discussion, Trembling at idle in Cadillac ATS Discussion Forums; Originally Posted by Chrispy Are you guys trying any fuel injection cleaner or going for a really spirited drive once ...
  1. #376
    sebounet's Avatar
    sebounet is offline Cadillac Owners Member
    Automobile(s): cadillac ATS 3.6 AWD performance
    Nov 2013
    Montreal, Canada
    49
    95
    Re: Trembling at idle
    Quote Originally Posted by Chrispy View Post
    Are you guys trying any fuel injection cleaner or going for a really spirited drive once a week (Several WOT runs)? Not saying it'll fix anything but was curious.
    I always drive in a spirited way. May be that's why the shake dissapeared ?. I have had also an update of ECM. I tried also to use super gaz. But what was strange is that the shaking appeared again, and disapeared after 200 miles around. I cambe back to regular, engine is a bit noiser from outside the car, but no shaking
    I think they need to replace engine mounts on some cars
  2. #377
    GJB's Avatar
    GJB
    GJB is offline Cadillac Owners Connoisseur
    Automobile(s): 2013 ATS4 3.6 Premium Build Date 12/21/2012
    May 2013
    Northern VA
    1,608
    Yes to both questions. Techron every 3k and spirited driving every chance I get. I also use Top Tier 93.
    Going WOT does correct the trembling and makes me forget about it....
  3. #378
    JavaGirl is offline Cadillac Owners Fanatic
    Jun 2013
    288
    This must be the longest running thread, ever, on here.
    Mine started trembling a little in the morning when it is cold. It stops it after about two to three minutes, and acts right at all other times. I don't like this, and sure hope it does not get worse!
  5. #379
    Cadillac Cust Svc's Avatar
    Mar 2010
    Detroit, USA
    12,697
    Quote Originally Posted by JavaGirl View Post
    Hi JavaGirl,
    I can understand your concern with your car trembling. If you would like to discuss the issue please PM me your VIN and contact information. Hope to hear from you soon.
    Austin J.
    Cadillac Customer Care
  6. #380
    torkibe is offline Cadillac Owners Fanatic
    Automobile(s): 2013 ATS 3.6
    Mar 2013
    153
    8700 miles of very spirited driving and a few bottles of techron later and the tremble is worse than ever.
  7. #381
    rustybear3's Avatar
    rustybear3 is offline Cadillac Owners Connoisseur
    Automobile(s): 2013 ATS White Pearl Turbo
    Feb 2012
    Ohio
    65
    1,681
    2014's having a problem similar to a 2013? Who'd have thunk it! Everyone knows those bugs are worked out in 2nd year models
  8. #382
    bowtie_30 is offline Cadillac Owners Member
    Automobile(s): 2013 ATS 2.0T Premium
    Sep 2013
    36
    I've had this issue twice in the last week. I'm at a complete stop at a red light, in first gear with the clutch all the way in. The engine starts to shake, the RPMs jump up to 1500-2000 then go back down. Then last night in the parking lot of Kroger I reversed out of the spot, put it in first and went to the end of the aisle. Stopped, waited for a car to pass then started to pull the clutch out and the car just started jerking forward. Popped it out of first and put it back in and it started jerking forward again. Turned the car off then back on, it did it again then the power steering went out and the car died. Then it wouldn't turn back on. Let it sit for a minute and it started and was just fine. I just dropped it off at the dealership and we shall see if they can fix it. Thank goodness I was in a parking lot and not a busy intersection when it happened.
  9. #383
    DY905's Avatar
    DY905 is offline Cadillac Owners Member
    Automobile(s): ATS 2.5L
    Mar 2014
    54
    1
    I've had my ATS 2.5L (basic model) for 6 months. It "rough idles" all the time. It is more noticeable when the engine is cold and gets less noticeable once the engine warms up. There was a general recall from GM on this issue when they tried to address the problem by reprogramming some vehicle software... that did NOT fix anything for me. Recently I have been told that this particular 4-cylinder 2.5L engine had this flaw since 2009. This engine is used on Chevy's and other GM vehicles (so much for Cadillac technological ingenuity). During my last visit to the dealer, I was told that there is nothing that can be done about the problem. That's the way the engine was designed. If this is a design problem known since 2009, why is GM putting these engines into new ATS's and advertising the ATS as "all new technology"? The biggest case of false advertisement I've seen! Very disappointing. I will never buy a Cadillac again and will not recommend it to anyone I know.
  10. #384
    carolina 2005 is offline Cadillac Owners Member
    Automobile(s): ATS 2.5 RWD
    Jan 2014
    21
    I got the first idle update and it fixed my problem, maybe you can get a dealer to redo the update. Maybe there was some reason it didn't take. Hope you can get it fixed.
  11. #385
    Hoosier Daddy's Avatar
    Hoosier Daddy is offline Super Moderator
    Automobile(s): 2013 ATS Performance 2.0T M6
    Feb 2013
    Winchestertonfieldville, AZ
    68
    6,076
    Quote Originally Posted by carolina 2005 View Post
    Definitely worth a try. And if that TSB doesn't fix your problem, that doesn't mean Cadillac doesn't have an obligation to find the cause of your problem and fix it,
  12. #386
    BLitzkrieg is offline Cadillac Owners Fanatic
    Automobile(s): 2009 CTS-V
    Aug 2010
    42
    304
    I am wondering if this has to do with the Electric Power Steering Rack. I had an issue where the car was rough idling and actually stalling right before the George Washington Bridge of all places. When I quickly restarted the car, I got a "Service Power Steering" light on the DIC. I had no power steering, but the idle was rock steady and smooth. Could the steering rack cycling on and off place a load on the engine, causing the rough idling. The idle can be so bad that the car feels like it is wagging its tail.
  13. #387
    Jan 2014
    21
    As far as I know there are two updates for the 2.5L rough idle. The first one was just for the ECM, that is the one that fixed my problem. The second one is for the ECM and the FUEL PUMP. DY905: You need to talk to the dealer and see which one you got. If it was the first one and they only did the ECM then they need to try the second update with the ECM and the FUEL PUMP. It says on the TSB that the ECM and the FUEL PUMP update need to be run separately and NOT together.
  14. #388
    Sep 2013
    36
    My dealer looked at the computer, noted that there were no codes and no misfires but noticed a variance in the idle. They had the car "re-learn" it, it's like night and day now and we shall see if the rough idle occurs again anytime soon.
  15. #389
    Feb 2013
    68
    6,076
    Quote Originally Posted by bowtie_30 View Post
    That's great!
    More detail please on what "they had the car re-learn" means.
  16. #390
    GJB's Avatar
    GJB
    May 2013
    Northern VA
    1,608
    I bet they just did a reset of the ECM (re-learn), but intrested in more detail also.
  17. Remove Advertisements
