Break in period
cadillac ats forums cadillac ats forums
Results 1 to 6 of 6
Cadillac ATS General Discussion Forum Discussion, Break in period in Cadillac ATS Discussion Forums; So who follows the recommended break in period? I have the 2.0T and have gone above the recommended 4k rpm ...
    03firebolt9r is offline Cadillac Owners Member
    Automobile(s): ATS 2.0T
    Dec 2012
    Dallas
    45
    36
    Break in period
    So who follows the recommended break in period? I have the 2.0T and have gone above the recommended 4k rpm a couple times. Curious what everyone else thought. I have read several different philosophies that differ from the manual. Not Cadillac specific though, generally motorcycle specific...though an engine is an engine.
    slowdriver's Avatar
    slowdriver is offline Cadillac Owners Member
    Automobile(s): Still negotiating
    Dec 2012
    Indiana
    59
    38
    Re: Break in period
    I always follow the guide lines and have never had oil usage issues. Different strokes for different folks , I treat it right and make mine last a long time..I have not had a engine issue since 1979 in my 1969 Vette. Bought a rebuilt motor and the pump lost it's prime. Did not get 2,000 miles on it when it started knocking.
    Bertha D Blues Guest
    Re: Break in period
    I'm following the 4k rpm break-in rule in my 2.0T. I don't mind waiting until I can have some real fun with it.
    Dec 2012
    Dallas
    45
    36
    Re: Break in period
    I really try to stay below 4k rpm, lol. Thanks for the input guys.
    blue_skies is offline Cadillac Owners Fanatic
    Automobile(s): ATS 3.6L Luxury
    Oct 2012
    52
    235
    Re: Break in period
    Quote Originally Posted by 03firebolt9r View Post
    The engines have already gone through some type of manufacturer's break in, and it is not as sensitive as may have been the case in years past.
    Things to avoid are excessive heat buildup, excessive high revving before the parts have settled and long stretches at same engine rpm (cruise control).
    By 1k miles most of the engine components will have settled.
    I follow the thought of break in hard (no cruise control, normal driving) but avoid high revving and high heat until past 2k miles. I deliberately avoided freeways because of this in the first 400 miles or so.
    Fwiw - I was surprised when I wanted to change oil at 1k miles - the dealer basically said: "What does the oil-life meter suggest? Wait for that." This tells me that Cadillac also doesn't see much grit coming out of the engine during the first 1k miles anymore either. (Or, the oil filters/sump system are big enough to not get clogged).
    BTW - I have very similar experience for other new engines in years past, including motorcycle engines. Especially with the high revving motorcycle engines, the 'slow low revving break-in' is a no-no. Better to cycle that engine, but don't let it get too hot until all the parts have settled. With a motorcycle engine, there is a max redline, that increases as more miles are driven - you don't want to start there, but long cruising (constant RPM) runs during the break in period causes irregularities that stay for the life of the engine as parts settle around that RPM range differently. Something that you don't want.
    Yplus is offline Cadillac Owners Fanatic
    Automobile(s): ATS4 Turbo
    Oct 2012
    Long Island, NY
    197
    I lasted about 350 miles and then realized two simple truths: Engines today have tolerances on the order of 1/10000th of an inch, they used to be in the 1/1000ths of an inch.. They have to break in the engines at the factory otherwise warranty issues would be huge. Since that's done on a dyno, I think the engine, transmission, rear exhaust and heat shields need to mate well which happens during the first couple of heat cycles. If you keep those first heat cycles pretty tame, you've basically done all you can do. It's a good excuse in my opinion, I'm not a very patient man after waiting 8 weeks for mine!
  9. Remove Advertisements
