8-speed automatic - Page 2
cadillac ats forums cadillac ats forums
Results 16 to 30 of 31
Like Tree2Likes
Cadillac ATS General Discussion Forum Discussion, 8-speed automatic in Cadillac ATS Discussion Forums; goob....
  1. #16
    thebigjimsho's Avatar
    Automobile(s): ZIP
    In the barrel of a gun...
    51,885
    goob.
  2. #17
    mikesul is offline Cadillac Owners Enthusiast
    Automobile(s): 16 2.0T Perf, 8spd auto, dp, E85, tune
    Aug 2010
    S FL
    808
    Re: 8-speed automatic
    I have heard rumblings of seven speed manuals and 8 speed autos for the C7 Corvette. Thats just over a year away.
  3. #18
    pragmatic is offline Cadillac Owners Member
    Automobile(s): None
    Aug 2012
    56
    51
    First quarter 2014 (does not report which vehicles will use it only that it is RWD) Trucks may be first appication
    http://www.13abc.com/story/18769971/...d-transmission
  5. #19
    zr1mom's Avatar
    zr1mom is offline Cadillac Owners Fanatic
    Automobile(s): ATS Prem 2.0T AWD Black Raven Red
    Nov 2012
    177
    Quote Originally Posted by JimmyH View Post
    If you drive a Camaro LT and Camaro SS back to back, you will definitely feel a torque deficiency in the 3.6
    Funny I traded in a V6 Camaro for my ATS.
    The other reason for the 8 speed I would guess is a little better gas mileage. The BMW has the 8 speed and that's what the ATS is going after. The BMW right now is rated slightly higher than the ATS.
  6. #20
    HandletheTruth is offline Cadillac Owners Member
    Automobile(s): NONE
    Nov 2012
    Virginia USA
    48
    Saw this basic link / reply in a separate URL discussing this topic. At the Aisin 8-speed auto transmission website (see attached URL below), it indicates a 5% acceleration advantage and a 7% fuel economy advantage versus a standard 6 speed auto. These improvements in both acceleration & fuel economy are significant and would be difficult to implement using other approaches. I hope the 8-speed is not much heavier than the 6-speed, which also shifts very smoothly. When will the 8-speeds be available in the ATS?
    http://www.aisin-aw.co.jp/en/product...n/at/at01.html
    Note: Highlight the URL above, right click on it; select the "Go to http://www.aisin-aw.co.jp/en/products/drivetrain/at/at01.html"
  7. #21
    Its an ATS is offline Cadillac Owners Fanatic
    Automobile(s): ATS Premium 3.6 AWD
    Oct 2012
    32
    235
    The whole trans/diff needs a rework. The Audi S4 has 333 hp through a 7 speed auto and runs a 12.9. It is also 3800 lbs. it's not all about 0-60 and 1/4 miles, but there is def some work to be done as far as putting power to the pavement. If cadillac can fix that with an 8 speed, then by all means.
  8. #22
    bdwalters is offline Cadillac Owners Fanatic
    Automobile(s): 2013 ATS 2.0T Premium
    Jan 2013
    Austin, TX
    223
    I have heard that the ATS will have the Aisin 8-speed next year and then a GM-sourced 8-speed after that. I guess we'll see. The BMW 8-speed is pretty amazing, so if GM can duplicate that, the ATS will be even better (and it will take away one of the 3's few advantages).
  9. #23
    Atswatcher is offline Cadillac Owners Fanatic
    Mar 2012
    246
    I have compared the 8 speed in the new 3 series and the 6 speed in the ATS, there is no advantage of 8 speed other than maybe slightly more mpg. If you are like me used to drive in manual mode, 8 speed is actually worse.
  10. #24
    Automobile(s): NONE
    Nov 2012
    Virginia USA
    48
    Previous entry in this thread - Saw this basic link / reply in a separate URL discussing this topic. At the Aisin 8-speed auto transmission website (see attached URL below), it indicates a 5% acceleration advantage and a 7% fuel economy advantage versus a standard 6 speed auto. These improvements in both acceleration & fuel economy are significant and would be difficult to implement using other approaches. I hope the 8-speed is not much heavier than the 6-speed, which also shifts very smoothly. When will the 8-speeds be available in the ATS?
  11. #25
    Wideband is offline Cadillac Owners Member
    Aug 2012
    33
    The link provided is incorrect with page not found error.
  12. #26
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,986
    The hyper-link is broken - got the ellipses (...) thrown into the actual link instead of just the link text... the link in quotes at the end is good
  13. #27
    Automobile(s): NONE
    Nov 2012
    Virginia USA
    48
    Also, try the link from my previous entry dated 11-24-12 in this thread. This original link worked for me just now.
  14. #28
    Jan 2013
    Austin, TX
    223
    There are multiple advantages with an 8-speed: better mileage, better acceleration, and smoother, faster shifts. The 8-speed in the BMW 3 is better than the 6-speed in the ATS, although the one in the ATS is still very good. There is a reason that companies are spending the money to develop 8-speeds for cars. Now if you like to manual shift quite a bit, I can see that being irritating, but it's otherwise hard to argue that and 8-speed isn't clearly better than a 6-speed, assuming they have similarly good engineering.
  15. #29
    rustybear3's Avatar
    rustybear3 is offline Cadillac Owners Connoisseur
    Automobile(s): 2013 ATS White Pearl Turbo
    Feb 2012
    Ohio
    65
    1,659
    This is all about meeting stringent new federal fuel economy regulations set for 2017 as well as similar standards coming in Europe. That's why GM and Ford are forming an alliance for development to save costs. The so called acceleration benefits, yada yada, are a sales pitch to justify the higher car cost for the tranny.
  16. #30
    Macvicar24 is offline Cadillac Owners Member
    Automobile(s): 2007 White Diamond Escalade, 2013 ATS Thunder Grey
    Nov 2011
    41
    36
    Maybe the announcement of the new Chevy SS Sedan next week will involve a new 8 speed auto with the new LT1 attached to it.
  17. Remove Advertisements
