Allante A/C not cooling well at idle
Results 1 to 2 of 2
Like Tree1Likes
  • 1 Post By RustyW
The Cadillac Allante Lounge Discussion, Allante A/C not cooling well at idle in Cadillac Allante Forum; My Allante A/C is not cooling well at idle. I have noticed that the radiator fans run for about 25 ...
    carguystl1 is offline Cadillac Owners Member
    Automobile(s): 1992 allante
    Jul 2011
    54
    1
    My Allante A/C is not cooling well at idle. I have noticed that the radiator fans run for about 25 seconds, and then shut off for about 1 minute before turning on again. The system is fully charged. Should the fans run all the time when the ac is on ??
    Thanks, Jeff
    RustyW is offline Cadillac Owners Member
    Automobile(s): Allante
    Mar 2010
    46
    3
    Re: Allante A/C not cooling well at idle
    I am not an expert in this area but I would expect that the fans would run to get rid of the heat exchanged in the AC process. If the ac is not working well at idle then i would consider that the compressor may be worn and not efficient at low rpm.
    STVINBAKO likes this.
