1990 allante run problem
Results 1 to 3 of 3
The Cadillac Allante Lounge Discussion, 1990 allante run problem in Cadillac Allante Forum; I have a 90 allante that runs rough until I loosen gas cap to let pressure of which seems like ...
    rollbackdriver is offline Cadillac Owners Member
    Automobile(s): none
    Aug 2010
    42
    1
    I have a 90 allante that runs rough until I loosen gas cap to let pressure of which seems like a whole lot of pressure, and it runs fine. I also hear a gurggly sound coming from the area of gas tank. Anybody had this problem?
    Feb 2003
    california
    69
    6,663
    Re: 1990 allante run problem
    I would look at the vapor canister hosing and/or the filter within it. There should be some pressure in the tank normally but releasing it should not affect running.
    Feb 2003
    california
    69
    6,663
    Also there was a recall on gas caps on some years of Allantes. The vent portion would stick.
