Results 1 to 4 of 4
    Chuck Linzey is offline Cadillac Owners Member Cadillac(s) I Drive: Cadillac Allante 1988
    Dec 2006
    Towson MD
    63
    32
    idle problem when hot
    problem for anyone out there. Rough idle only when car gets hot. Over half way up on the gauge. If gauge is below half (which it normally is) runs and idles great. Of course I have not done plugs, wire or any tune-up yet. This normally happens when car is in heavy slow traffic or at idle. One you get moving temp goes down and idle is smooth again. (Both fans are working).
    Car does not overheat even if at idle for hour.
  2. Cadillac Network Advertisements Registered members do not see these ads. Click here to remove them.
    Always
    Advertising world
    2010
    Many
    Allantesource is offline Cadillac Owners Fanatic
    West Palm Beach, FL.
    184
    Re: idle problem when hot
    We had an Allante' come in with the same complaint a couple weeks ago. It didn't even run well cold as far as I was concerned. It had original spark plug wires and we found a lot of arching inside the cap. In the replacement process found one of the plugs was wet. After a tuneup- plugs wires cap rotor it was better and probably good enough but still not 100%. An ECM got it the rest of the way. So bottom line it could be any of above, or a combination, or possibly even an injector problem. Original spark plug wires are beyond their expected service life. If you do replace the wires, make sure sure you use coated plugs or coat the exterior of the plugs with suitable silicone or di-electric grease or the boots will weld onto the plugs.
    Dec 2006
    Towson MD
    63
    32
    Thanks, plugs and wires next step. I have tried to contact Allantesource by email but no response.
  5. Sponsored Cadillac Advertisements (Supporting Members don't see these ads):
    Stealth's Avatar
    Stealth is offline Cadillac Owners Enthusiast Cadillac(s) I Drive: Is one enough ?
    Jun 2003
    So CA
    706
    Quote Originally Posted by Chuck Linzey View Post
    go back and take a look at your original thread:
    "recent purchased a 1988 few questions"
Simply register and/or login to remove these advertisements.
  • You may not post replies
custom floor mats | cadillac performance mufflers | cadillac performance exhaust systems | racing seats | cadillac euro tail lights | cadillac air intakes | cadillac projector headlights | cadillac ground effects | cadillac floor mats | cadillac escalade body kits, hoods and lambo doors | cadillac body kits | cadillac carbon fiber hoods | air suspension kits | air suspension parts | air ride suspension | hyundai genesis forum | kia forte forum | used car savings
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183
