1987 Allante electrical system problem
Results 1 to 3 of 3
Cadillac Allante Forum Discussion, 1987 Allante electrical system problem in Past Cadillac Vehicle Discussion; My Allante is acting as though there is no battery in it. I know the battery is fine but everything ...
    surfside is offline Cadillac Owners Member
    May 2006
    3
    Angry1987 Allante electrical system problem
    My Allante is acting as though there is no battery in it. I know the battery is fine but everything is dead. When I turn the key, nothing happens, nothing lights up, etc. Any ideas?
    Allantesource is offline Cadillac Owners Fanatic
    West Palm Beach, FL.
    188
    Re: 1987 Allante electrical system problem
    It is possibly a bad connection somewhere, or blown fuses. Check all the fuses, including the rear fuse panel in front of the antenna in the trunk. What does get power? DIC? Radio? Window switches? Headlights? Horn?
    May 2006
    3
    Thank you. The last thing I suspected was a run down battery since I had a new one installed only 2 weeks ago. My mechanic tracked the battery drain to the top pull down motor.
