89 Allante Owner needs help
Results 1 to 3 of 3
Cadillac Allante Forum Discussion, 89 Allante Owner needs help in Past Cadillac Vehicle Discussion; Hello, I have an Allante that would not shut off (even with key removed). I disconnected the battery/fuses and it ...
    MarkMario is offline Cadillac Owners Member
    Apr 2006
    4
    Hello,
    I have an Allante that would not shut off (even with key removed). I disconnected the battery/fuses and it is now stopped.
    A friend told me that I need a new ignition switch. So I have ordered one. However, my Service Information Manual shows something in the steering column with 10 different plugs in it and the internet shows a key cylinder thing.
    Which should I replace? Am I on the right track?
    Please help?
    MarkMario
    Bob Rich is offline Cadillac Owners Member
    Feb 2005
    56
    Re: 89 Allante Owner needs help
    Since the switch itself is remote from the cylinder, it could be either one, or the linkage between them.
    Apr 2006
    4
    Thank you.
    I'll start replacing everything.
