fuel filter
Results 1 to 4 of 4
Cadillac Allante Forum Discussion, fuel filter in Past Cadillac Vehicle Discussion; I am a new owner of a '92 Allante and I want to change the fuel filter. Who can tell ...
    nobse is offline Cadillac Owners Member
    Apr 2005
    fuel filter
    I am a new owner of a '92 Allante and I want to change the fuel filter. Who can tell me the location of the filter and the special needs for the change (tools, etc.)?
    Kcryan is offline Cadillac Owners Fanatic
    Automobile(s): 1992 Tripple Black Allante, RIP 98 catera
    Mar 2004
    257
    Re: fuel filter
    Wondering the same thing and too lazy to get out my service manual, free bump
    Doug Jackson is offline Cadillac Owners Member
    Automobile(s): 93 Allante 2004 DHS 2007 DTS Lux II
    Oct 2003
    atlanta ga
    78
    21
    Re: fuel filter
    The fuel filter is located inside the frame rail below the driver side door. Remove the fuel pump fuse and run engine till it quits. Open end metric wrenches required to remove and install filter. replace fuse crank car till it starts. Doug Jackson
    Bob Rich is offline Cadillac Owners Member
    Feb 2005
    56
    Re: fuel filter
    When starting after replacing the filter, crank for no more than about 3 or 4 seconds, then turn the key off and try another cranking cycle. The fuel pump shuts off after about 4 seconds of cranking unless oil pressure is detected.
  7. Remove Advertisements
