1989 Allante Battery Location
Results 1 to 10 of 10
Cadillac Allante Forum Discussion, 1989 Allante Battery Location in Past Cadillac Vehicle Discussion; Hi all, A friend purchased a '89 Allante and I want to help him replace the battery. The only problem ...
    ayrton is offline Cadillac Owners Member
    Jan 2004
    4
    Question1989 Allante Battery Location
    Hi all,
    A friend purchased a '89 Allante and I want to help him replace the battery. The only problem is finding it. If anyone could help out giving us the battery location, it would be appreciated.
    Thanks in advance,
    ayrton
    Jan 2004
    4
    Hi all,
    Could anyone help out giving me the battery location in a '89 Allante.
    Thanks in advance,
    ayrton
    ipncjh1's Avatar
    ipncjh1 is offline Cadillac Owners Member
    Automobile(s): 2014 XTS Vsport Platnium
    Jun 2003
    Lucas Texas USA
    56
    Re: 1989 Allante Battery Location
    Search of the web shows it is behind the right front passenger seat under a panel. Let us know!
    Jan 2004
    4
    Quote Originally Posted by ipncjh1
    Thanks for the help. Your web search was better than mine.
    I will advise.
    Thanks,
    ayrton
    El Dobro's Avatar
    El Dobro is offline Cadillac Owners Connoisseur
    Sep 2003
    1,471
    Re: !989 Allante Battery Location
    Behind the passenger seat, on the shelf, there's a speaker enclosure. Turn on the radio and listen, you'll hear the speaker. You have to slide that panel forward carefully because the speaker wires are right there. When you have it released, disconnect the speaker. There's the battery. Make sure you use a battery that has the same vents so you can comnnect the vent hoses that direct the gases under the car. Also, you friend should keep an eve out on eBay for a factory service manual. They're priceless when it comes to the Allante.
    Jan 2004
    4
    Thumbs upRe: !989 Allante Battery Location
    Thanks for your time. I appreciate it.
    ayrton
    Automobile(s): 1999 BMW 740 Il. 2005 Jag XK8, 1988 Mercedes Benz 300 SE
    Feb 2003
    california
    69
    6,688
    I own an '88 Allante, the battery is just behind the passenger seat. power the right seat forward, look at the carpeted panel thats vertical behind the seat. Mine has a key lock access, not sure if an '89 is the same. Unlock the panel if necc. pull forward towards the seat back. Viola! theres the battery. If you are replacing it, I would recommend a Delco only that has the external vent hose attachment provision. hope this helps, Bill.
    Allante North *'s Avatar
    Allante North * is offline Banned
    Automobile(s): 1993 Triple Black Allante
    Dec 2002
    Rocky Top Tennessee
    57
    701
    Welcome to CadillacForums ayrton!
    I am glad you found us, and I hope you friend with the Allante joins us as well. I think you will get much from this site, and we will try to help in any way we can with Allante questions and Cadillacs in general. Let us know if you need any other info on the Allante. I have several years experience with them and if I don't know the answer I can sure point you in the right direction.
    Stealth's Avatar
    Stealth is offline Cadillac Owners Enthusiast
    Automobile(s): Is one enough ?
    Jun 2003
    So CA
    646
    Thumbs upany Allante Battery Location, misc manual pulls, GEL battery
    Quote Originally Posted by ayrton
    Hi all,
    Thanks in advance,
    ayrton
    all unmodified Allantés have the battery behind the passenger seat .. to pull the panel, use your trunk key to unlock and then simply pulll the panel forward .. not sideways .. be carefull to wash the area qucikly with baking soda, and if any got spilled on carpet, sprinkle baking soda and shampoo the area, ASAP, within 5 minutes .. highly recommend a towel to cover the carpet while pulling battery ...
    as a side issue, there is a similar panel behind the driver side, and there you will find the EMERGENCY / manual fuel door release ... something to know just in case the power switch fails .. btw, the BOSE speakers are inside these panels ...
    if you are not familiar with the other manual releases, top, trunk, top boot, compartment separator, park brake, etc ... drop me a line .. you should know where they all are .. another one that gets many in trouble is the parking brake manual release, if the auto-release fails, you are stuck unless u can find the manual release .. know them all .. and no , there is NO seat ejection ...
    as to the battery, GEL batteries are what many of us are switching to .. NO acid spill or leaks or fumes ... lasts only 3 - 4 years as compared to 6 yrs for the Delco liquid units, but it is worth not having acid issues back there .. the Delco have a LONGGGGGGGG history of leakage and damage not only to the tray, but to carpeting, upholstery, etc .. GEL - several brands and all work well ...
    Stealth's Avatar
    Jun 2003
    So CA
    646
    Hi all,
    Thanks in advance,
    ayrton
    seems to be an ECHO thread ...
    wht the heck, here is my echo response:
  13. Remove Advertisements
