Radio ?
Results 1 to 7 of 7
Cadillac Allante Forum Discussion, Radio ? in Past Cadillac Vehicle Discussion; I have a 1990 model and the volume of the radio is very low. I can turn up the volume ...
    Boofer is offline Cadillac Owners Member
    Sep 2005
    7
    UnhappyRadio ?
    up the volume but there is no responce;any ideas?
    Thanks in advance
    DON
    CadillacSTS42005's Avatar
    CadillacSTS42005 is offline Banned
    Automobile(s): 2005 STS4 1SG: GM Acc Lights, Corsa, Platnium Grille, Volant
    Oct 2005
    15,987
    Re: Radio ?
    sounds like am amp problem to me
    Feb 2003
    california
    69
    6,680
    Re: Radio ?
    Try disconnecting the battery, sometimes re booting the system restores it. I
    presume you know how to reset the clock after re connection. Beyond that I would suspect the reciever behind the glove box. Each speaker has its own amp so I would not suspect 4 amps bad.
    btimmer is offline Cadillac Owners Member
    Jun 2005
    The great north, Minnesota
    69
    5
    Re: Radio ?
    I have a '90 and just had the same problem. I could hear the radio but only with the engine not running and the radio on high. I bought one new speaker and it didn't help at all. I then removed the radio and had it rebuilt and now it works fine. Now as long as I am working on this system, I am going to replace the capacitors on the speaker amps to eliminate another problem in the future. Good luck.
    Quote Originally Posted by Boofer
    Thanks in advance
    DON
    HawkerDR is offline Cadillac Owners Member
    Jan 2006
    7
    Re: Radio ?
    I have a 91 model and had the same thing with the radio. I wasted alot of money replacing all the speakers as everyone said that was the problem. After changing out $400 in speakers and problem not fixed i replaced the receiver behind the glove box for $100 and all worked fine. My symptoms were similar to yours in that the volume was low and then went to only 1 speaker and then finally quit. My advice would be to replace the receiver first then move on from there. The reason i changed the speakers first is that they were dying 1 at a time, so automatically thought that was the problem.
    gmkiwi is offline Cadillac Owners Member
    Jan 2006
    6
    Re: Radio ?
    I noted the comments about the receiver. I have a 90.5 with failing speakers, they only work after the radio has been on for a period of time. Any advice where to purchase this Receiver. Thanks.
    Jan 2006
    7
    Re: Radio ?
    Doctor Dons in Huntsville, Texas. I dont have his number right now but i am sure if you google him you will find it.
  10. Remove Advertisements
