1992 Allante Rear Strut Replacement
Results 1 to 5 of 5
Cadillac Allante Forum Discussion, 1992 Allante Rear Strut Replacement in Past Cadillac Vehicle Discussion; Recently purchased 1992 Allante - Rear struts are bad. Am having difficulty getting OEM replacement (electric). Only thing I have ...
    Flash0921 is offline Cadillac Owners Member
    Automobile(s): 1992 Allante
    Aug 2014
    Recently purchased 1992 Allante - Rear struts are bad. Am having difficulty getting OEM replacement (electric). Only thing I have been able to find is Munro aftermarket type. Questions: Can the original electric be replaced by gas/oil struts without the electric interface and if so does it punch a suspension code or notice on the dash. Your support and knowledge would be appreciated...... Thanks............Dale
    smumfor's Avatar
    smumfor is offline Cadillac Owners Member
    Automobile(s): 89 Allante / 90 Allante
    Jun 2003
    Jacksonville, FL
    21
    Re: 1992 Allante Rear Strut Replacement
    I replaced all 4 of mine about a year ago and It rides and handles great.. Dick Hussey ( AllanteSource.com ) sent me the information on how to turn off the DIC message
    kiwigram is offline Cadillac Owners Member
    Automobile(s): '92 Allante, '93 Allante
    Nov 2007
    New Zealand
    76
    I replaced the rear struts on my 90.5 a few years ago with the SunCore Pneumatic leveling. I never received any codes and they did a great job for me. I then replaced the front struts with SunCore replacement units. They included a resistor that wires in to the strut sensor to compensate for the SDD. However, they didn't work so I had to adjust the computer to cancel the DIC message.
    Aug 2014
    Is the resistor supplied for the rear and is it easy to install so you don't have any dash messages? Also, when the resistor didn't work for the front, what did you do to remove the message?
    The funny thing is that my struts are bad (hitting bottom all of the time), but I don't have any codes or messages showing..
    Nov 2007
    New Zealand
    76
    The resistors are supplied for the fronts only. On the rear, I just taped the wires out of the way and never had any message to indicate non-functioning. As for the front, I went to Dick Hussey's web site and followed his directions on how to adjust the BCM to eliminate the message.
  8. Remove Advertisements
