Need info on 89 Fuel Injectors correct OHM range readings
Results 1 to 3 of 3
Like Tree1Likes
  • 1 Post By Navion01
Cadillac Allante Forum Discussion, Need info on 89 Fuel Injectors correct OHM range readings in Past Cadillac Vehicle Discussion; I need to check the injectors of my 89 Allante. A friend of mine knows how to do the procedure ...
    Allanteguy89 is offline Cadillac Owners Member
    Automobile(s): 1989 Cadillac Allante
    Aug 2014
    50
    6
    QuestionNeed info on 89 Fuel Injectors correct OHM range readings
    I need to check the injectors of my 89 Allante. A friend of mine knows how to do the procedure and has an OHM meter, but I need to know what the proper range is for a functioning injector vs. a bad or defective one. Any help would be appreciated. Thanks.
    Navion01 is offline Cadillac Owners Member
    Automobile(s): 1989 Allante
    Sep 2014
    69
    Re: Need info on 89 Fuel Injectors correct OHM range readings
    Hi! Can't tell you what the ohm range is for your injectors, but I can tell you that your DIC will test them individually and tell you which ones are good or bad. I can also
    tell you how I resolved my injector issue in my 89. I put Ford High performance Mustang Injectors in Part # M-9593-AA302. Available from American muscle and other
    suppliers. You want the 24# injectors not the 30# units. They increased my performance and mileage and a set of 8 was under $200. Good Luck!
    carnut likes this.
    Feb 2003
    california
    69
    6,663
    AS mentioned in the above post, each injector can be tested thru the DIC simply by pushing the correct buttons. I presume you dont have the factory service manual?
