Help please - 7.5 amp injector fuses keep blowing out on my 1989 Cadillac Allante
Results 1 to 3 of 3
Cadillac Allante Forum Discussion, Help please - 7.5 amp injector fuses keep blowing out on my 1989 Cadillac Allante in Past Cadillac Vehicle Discussion; I have a 1989 Cadillac Allante and for some reason about every two weeks or so the fuel injector fuse ...
    Allanteguy89 is offline Cadillac Owners Member
    Automobile(s): 1989 Cadillac Allante
    Aug 2014
    50
    6
    QuestionHelp please - 7.5 amp injector fuses keep blowing out on my 1989 Cadillac Allante
    I have a 1989 Cadillac Allante and for some reason about every two weeks or so the fuel injector fuse blows, and when I replace it it will usually last for another week or so. Both injector fuses are blowing out sporadically and I can't figure out why. I did the computer diagnostic check and it didn't come up with any codes that would point me in the right direction. The car also is lacking power - it takes awhile to get up to speed, especially uphill, but once you get going it drives OK. It starts and idles smooth, I've had a complete tune-up performed. It occasionally backfires on acceleration and my muffler recently exploded with a large bang, and I've got gasoline in my oil. When the car starts to stall at stop lights or looses a large amount of power I shut the car off, check the fusepanel and sure enough, one of the injector fuses has blown out again. Any help would be appreciated.
    Navion01 is offline Cadillac Owners Member
    Automobile(s): 1989 Allante
    Sep 2014
    69
    Re: Help please - 7.5 amp injector fuses keep blowing out on my 1989 Cadillac Allante
    I hope you have a service manual for your car. Hard to find this stuff without one. There is a routine that one can run in the computer diagnostic area that will check the injectors one by one. I think I would run that routine and see if you have any bad injectors.
    Automobile(s): 1999 BMW 740 Il. 2005 Jag XK8, 1988 Mercedes Benz 300 SE
    Feb 2003
    california
    69
    6,689
    First thing to do is visually inspect the wiring harness to the injectors. Blowing a fuse usually means a bare wire is touching metal. Any evidence of rodent wiring damage at the intake manifold area?
