anyone have experience with block sealants? ( head gasket leak )
Results 1 to 4 of 4
Cadillac Allante Forum Discussion, anyone have experience with block sealants? ( head gasket leak ) in Past Cadillac Vehicle Discussion; Thinking about using a head gasket sealant on my Northstar ( who would have guessed it would blow a gasket ...
    gewans is offline Cadillac Owners Member
    Automobile(s): None
    Aug 2014
    None
    16
    Thinking about using a head gasket sealant on my Northstar ( who would have guessed it would blow a gasket ) anyone have any experience with the brands out there.
    Tony S45 is offline Cadillac Owners Member
    Automobile(s): 1993 Allante
    Mar 2014
    Virginia
    23
    Re: anyone have experience with block sealants? ( head gasket leak )
    gewans:
    I'm sorry to read about your problem. How many miles does your car have?
    I also have a Northstar (64k miles) and change the coolant every two/three years and hope the engine will last, but who knows...
    To your question, I have read about numerous snake-oil potions that claim that they will fix a head gasket problem but unfortunately for every success there must be scores of failures. If that were to happen to me I would get a quote from a reputable mechanic that has experience with Northstars for a correct fix including new head bolts. Next, I would attempt to calculate whether it's worth it to fix the car or attempt to sell it for parts. I know this is not what you want to hear but it's the reality of an expensive aluminum engine. However, before I'd sell it for parts I would certainly try a reputable firms head gasket sealant such as Lucas.
    Keep us posted as to your progress.
    Tony S45
    Feb 2003
    california
    69
    6,643
    The head gaskets fail because the head bolts loosen and the head raises. I doubt any snake oil could fix that.
    Automobile(s): None
    Aug 2014
    None
    16
    Thanks for your reply. I have had many caddies with northstars and thought I would try sealant fix. A
    friend of mine with many years of experience fixing, fabricating, and racing tried sealant and it worked, for how long, who knows. I just wanted to give it a try. I can always pull the engine and replace the studs and do misc. maintenance. I live in Arizona and this is a bad time of year to rebuild motors. Thanks for your
    interest. I'll keep you informed.
  7. Remove Advertisements
