Overheats on the highway or at higher rpms for extened time
Results 1 to 9 of 9
Cadillac Allante Forum Discussion, Overheats on the highway or at higher rpms for extened time in Past Cadillac Vehicle Discussion; I have a 1990 Allante. It runs good and shifts good but when I take it on the highway or ...
    joetighe is offline Cadillac Owners Member
    Automobile(s): 1990 Cadillac Allante and a Black 2005 Cadillac Escalade ESV
    May 2013
    New Hampshire
    23
    I have a 1990 Allante. It runs good and shifts good but when I take it on the highway or on really hot days if I am holding a higher rpm it overheats. Under normal 40MPH roads it doesn't get above the middle bar. I have checked the fans with the DIC and they both work. The coolant level is good. I'm not sure where to start, with the fan speed or the water pump? Any help would be great!
    Feb 2003
    california
    69
    6,608
    Re: Overheats on the highway or at higher rpms for extened time
    Classic symptom of a restricted, plugged radiator. What do you consider " overheating" Does it boil over, or just that the gauge goes past center?
    May 2013
    New Hampshire
    23
    It has never boiled over. The hottest it's ever gotten is second to last bar. Any way to test the radiator?
  5. #4
    Feb 2003
    california
    69
    6,608
    First things to do are replace radiator cap with a DELCO brand one, then Burp the system to rule out trapped air in the system. THEN, take it to a radiator shop that has an infra red thermometer. They will test sections of the radiator for cooler areas. Cooler areas are blocked areas.
  6. #5
    smumfor's Avatar
    smumfor is offline Cadillac Owners Member
    Automobile(s): 89 Allante / 90 Allante
    Jun 2003
    Jacksonville, FL
    21
    Has the car ever overheated that you know of.... I am thinking Thermostat ... but most likely I agree with carnut the Radiator is clogged.
  7. #6
    May 2013
    New Hampshire
    23
    Thanks so much, I changed the thermostat when I bought the car because that was my first thought about the overheating. I will take it to a shop soon thanks!
  8. #7
    nbaum is offline Cadillac Owners Member
    Automobile(s): 1993 & 1992 Allante
    Oct 2013
    40
    I would change the thermostat first. My 92 would run hot and then all of a sudden drop. New thermostat fixed it.
  9. #8
    gdled is offline Cadillac Owners Member
    Automobile(s): '93 Allante
    Nov 2014
    76
    7
    Since pressurized water boils at a higher temperature an old radiator cap that won't hold pressure can cause the exact symptoms. A quick visual check is to see if the rubber gasket has spread out beyond the edge of the spring. You can compare new and old caps to see. But caps are so cheap, I'd do that first. Also, check your coolant viability. If you've been adding water to your cooling system, quit it, you are lowering the boiling point. Only add Delco coolant, and don't forget the GM coolant pellets for aluminum blocks....Also, consider flushing the system and refilling with the required coolant. And the pellets, don't forget the pellets...
  10. #9
    Feb 2003
    california
    69
    6,608
    Old thread! In my opinion, adding the pellets this late in the game only helps plug up the heater core and radiator. The pellets were invented and recommended to stop porosity leaks in the aluminum blocks, nothing else. Since the last posting back in July of 2014, nothings been updated. Another case of getting info then disappearing.
  11. Remove Advertisements
