OH the brakes!
Results 1 to 7 of 7
Cadillac Allante Forum Discussion, OH the brakes! in Past Cadillac Vehicle Discussion; I bought a second Allante back in February and have been working on it as time permits. The Car only ...
    smumfor's Avatar
    smumfor is offline Cadillac Owners Member
    Automobile(s): 89 Allante / 90 Allante
    Jun 2003
    Jacksonville, FL
    21
    OH the brakes!
    The Car only has 38,000 original miles and the body and Interior are in great shape. It has all the common problems with the Brakes and the Bose Amps etc.
    Well one of the front Calipers was sticking ..and Leaking so I replaced both fronts. I also Discovered that the Right rear is leaking so This coming weekend I will replace the rear Calipers. Problem is the front calipers seem to be sticking and the brakes are getting very hot ???? Last night when I got home they were going ..PING PING , Click Click and I could hardly touch the wheel it was so hot... Middle of the night.. I am awake thinking about it and.... Traction Control!
    The 90's had traction control that would keep pressure on the front brakes to keep me from a skid...
    So This morning I disconnected it and We will see what happens.
    Scott
    Automobile(s): 1999 BMW 740 Il. 2005 Jag XK8, 1988 Mercedes Benz 300 SE
    Feb 2003
    california
    69
    6,689
    Re: OH the brakes!
    You have a restricted brake hose. One or both front hoses at the caliper wont let the fluid return to the master cylinder. Traction control keeps you from spinning a tire on rapid acceleration. ABS keeps you from skidding on maximum brake application. A car with this low mileage never got the 2 year brake fluid flush. Common issue with garage queens!
    smumfor's Avatar
    Jun 2003
    Jacksonville, FL
    21
    Re: OH the brakes!
    You are right... I forgot about that.... I just went over and ordered 2 new front lines and I can pick them up at 2:30 today.
    Thanks!
    Scott
    desant78 is offline Cadillac Owners Member
    Automobile(s): 87 Cadillac Alante
    Jan 2015
    1
    Re: OH the brakes!
    Updating this thread. I just experienced the same thing. New calipers, rotors, and pads on all four corners, and bleed the car. driver side caliper seemed to keep sticking, and it ended up being the flex rubber brake line connected to the caliper. Thanks for pointing us in the right direction!
    smumfor's Avatar
    Jun 2003
    Jacksonville, FL
    21
    Re: OH the brakes!
    Quote Originally Posted by desant78 View Post
    Is the ABS on your DIC giving you an "OK" or did you have to replace the ACCUMULATOR ?
    They wear out just sitting for a long time..
    Also did you run the Codes ?
    Feb 2003
    california
    69
    6,689
    Re: OH the brakes!
    The accumulator stores nitrogen to provide extreme pressure to the anti lock system. Unless it leaks, it will last a long time.
    smumfor's Avatar
    Jun 2003
    Jacksonville, FL
    21
    Re: OH the brakes!
    My first Allante was 9 years old when I got it and first thing I had to do was replace the accumulator.
    My 90 had sat for over 15 years .. had 38,000 miles on her and it also had to be replaced when I got it last February.
  10. Remove Advertisements
