92 Allante Starter Motor Bolts
Results 1 to 2 of 2
Cadillac Allante Forum Discussion, 92 Allante Starter Motor Bolts in Past Cadillac Vehicle Discussion; I'm trying to figure out what size the starter mounting bolts are on a 92 Allante (4.5L). I called the ...
    Neils88 is offline Cadillac Owners Member
    Jun 2014
    1
    Question92 Allante Starter Motor Bolts
    I'm trying to figure out what size the starter mounting bolts are on a 92 Allante (4.5L). I called the dealer, they said they are discontinued, but did say they were M10x1.5 bolts, one 48.3mm, the other 131mm. I agree with the short bolt length, but the long bolt should be around 88mm by my measurements (measured the housing of the starter which is about 60mm....I don't have any actual bolts to compare with).
    Having said that....where can I buy these bolts? No where seems to have anything like that. I'm assuming I need GM knurled starter bolts (otherwise I could just go to Home Depot and pick up bolts).
    Feb 2003
    california
    69
    6,680
    Re: 92 Allante Starter Motor Bolts
    Same bolts on a 91/92 Seville. Wrecking yard?. Did you loose yours?
