1989 Allante no air coming out of vents
Results 1 to 4 of 4
Cadillac Allante Forum Discussion, 1989 Allante no air coming out of vents in Past Cadillac Vehicle Discussion; I have a 1989 Allante with absolutely no air coming out of the vents. The blower motors works and I ...
    briggs70 is offline Cadillac Owners Member
    Automobile(s): 1969 Eldorado, 1989 Allante
    Oct 2011
    Stow, Ohio
    47
    I have a 1989 Allante with absolutely no air coming out of the vents. The blower motors works and I can hear it running and I can feel a very little air coming from the top vent by the windshield, but other than that nothing else. Even if I position the Air Selector to the bottom I get no air. Does anyone have any suggestions on where I could start looking for whats causing this issue.
    Thanks in advanced!!
    Feb 2003
    california
    69
    6,664
    Re: 1989 Allante no air coming out of vents
    First place to check is the vacuum supply hose from the engine to the firewall on the passenger side. If that's there, then pull out the glove box insert and confirm the blend door rod moves on the programmer. This is the silver rod thats threaded and attaches to the arm on the top of the programmer. With the car running, switch the climate display from 60 degrees to 90. Within a few seconds you should see this rod move slowly and smoothly from closing the blend door to fully opening it. If it barely moves or does not move at all, you need a programmer. Did this just happen recently? Was it working fine, say, 2 days ago and now doesnt?
    Oct 2011
    Stow, Ohio
    47
    No it has never worked for the three years I've had the car. Thanks for the suggestions I will follow your tips
    Thanks
    Feb 2003
    california
    69
    6,664
    Do you have the factory service manual? Because you own an Allante, it's very important.
  7. Remove Advertisements
