any hints on changing plugs
Results 1 to 7 of 7
Cadillac Allante Forum Discussion, any hints on changing plugs in Past Cadillac Vehicle Discussion; Ok i picked up a 89 red late last fall after two day's put into winter sleep over the winter ...
    silver haired fox is offline Cadillac Owners Member
    Automobile(s): allante
    Nov 2013
    ottawa canada
    64
    58
    Ok i picked up a 89 red late last fall after two day's put into winter sleep over the winter i got a manual & read ,the last month it FINALLY got warm enough to work on it so all fluid's changed, air & fuel filter all most all ground'a cleaned new battery and a lot of little thing's, now all system's go no codes it now even say's good morning to me .While doing this i found that the last owner wasn't a real maintenance type, so i thought i'd change the plug's.Well i wish the engineers who design
    the car's should have to work on them i'm not a big man but i feel like i have the arm's of the hulk! i've read that you can tilt the motor to do the back plug's could you lift the motor up so you can get more room to do the front one's. now before you comment the motor was rebuilt by a dealership at 80 th it now has 150 on it should i just sit back have a beer and shine it
    all's that is left to do is the radio that's next, but for now can't wait to drive with top down oh yea new soft top last year form last owner i think this car & i are going to have a great time hope to meet some of you soon
    BillFlorida is offline Cadillac Owners Member
    Automobile(s): Allante 1991
    Apr 2014
    54
    1
    Re: any hint's on changing plug's
    Hi Silver
    Just my perspective here. Really, I'd say it depends on the type plug installled in the engine. I have a '91 with 135 on the clock. It is still running the original plugs, which were indicated to go 100K I have had no issues to date, no issues that is that I can tell. I am sure that they need to be changed. I bought a new set of plugs, wires cap and rotor to install back at 90 K. When I realized what was involved I lost the giddyip to do it. Besides I'm getting decent enough economy, 15.4 average, 19 + if I take it easy.
    There are basically three ways to do the job. The first is from the top, across the engine. That way will no doubt wreck your hands due to the difficulty in getting into the confined area where the rear plugs are. The second method is to tip the engine and do it that way. I understand that this is a viable method for doing it. I just hasve difficulty in accepting that no "other" problems would arise from that . In tipping I would think that the trans lines, exhaust connections and cooler lines all would be stressed. With my run of luck I am hesitant to go that route. With the third method going underneath when the car is up on a lift, I think might be the safest and least costly, injury wise. You do have to route the plug wires so there will be some work from above, but that could be worked through. I'd favor the last method. I, like you, have not done it yet.
    In your case, if the engine was gone over at 80 K and you are only at 70 k on the plugs, I'd sit back and polish the car, unless you are noticing something.
    Bill
    jim e is offline Cadillac Owners Member
    Automobile(s): 1990.5 allante, 1990 allante
    Nov 2003
    AUBURN NY
    62
    54
    Bring the car to local Cadillac dealer and hope that they indeed replace all 8 plugs .Saves hands and issues. Some jobs are just better off paying someone else to do it.
    If local dealer has not done it in a while then get an estimate ahead of time and keep them to it when they come back with problems of access and extra time involved.
  5. #4
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Don't take it to the dealer, that would be up among the worst places to take it.
    Tilting the engine is the way to go. The whole engine tilts back and forth constantly while you drive, nothing's going to break. Disconnect the torque struts, and you can use a turnbuckle in place if one of them to tilt the engine forward.
  6. #5
    Nov 2013
    ottawa canada
    64
    58
    Thank's for all the input ,still debating thinking that if it an't broke
  7. #6
    rolandlittle is offline Cadillac Owners Member
    Automobile(s): none
    Jun 2014
    None
    1
    Re: any hints on changing plugs
    Get your socket with short extension. Lay on the intake and reach your arm around the back and take out plugs on rear engine. You will be working from the side.
  8. #7
    Feb 2003
    california
    69
    6,613
    Pull a plug on the front side and take a look at it. If its a platinum plug and looks good, leave them alone for now. I put DELCO platinum's from a 91 Eldo in my 88. Worked great. Went from 60,000 mile interval to 90,000 mile interval. If they are not DELCO, change them. I loosen the two front engine cradle (sub frame) bolts almost completely out and with a floor jack and a piece of wood under the oil pan. lower the engine gently. That requires the upper dog bone mount be removed. Just watch the exhaust coming down and forward in relation the the radiator.
  9. Remove Advertisements
