Transmission Issue, Hard Downshift
Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By joetighe
Cadillac Allante Forum Discussion, Transmission Issue, Hard Downshift in Past Cadillac Vehicle Discussion; This is my 2nd Allante, its a 1990 and its a non N*. Ive only had it about a week, ...
    joetighe is offline Cadillac Owners Member
    Automobile(s): 1990 Cadillac Allante and a Black 2005 Cadillac Escalade ESV
    May 2013
    New Hampshire
    23
    This is my 2nd Allante, its a 1990 and its a non N*. Ive only had it about a week, on the test drive it had no issues. I now have it home in New Hampshire from Rhode Island and the downshifts are hard. If i accelerate it shifts up at about 30 MPH and about 4000 RPM. It seems high to me. If Im driving and i need to accelerate up a hill and put my food down it slams down a gear. Upshifts are almost perfect. if i let my foot off the gas and manually put it into 2nd it will go smoother with no gas, than i shift back to D and it will shift up fine. I have read about the vacuum modulator, does this sound right? also read about the throttle valve cable.. a possibility. Any help would be fantastic. I love the allante's and would really like to fix this and make the drive more enjoyable.
    Automobile(s): 1999 BMW 740 Il. 2005 Jag XK8, 1988 Mercedes Benz 300 SE
    Feb 2003
    california
    69
    6,689
    Re: Transmission Issue, Hard Downshift
    Sounds like a TV cable adjusted too short. Any good trans shop should be able to adjust it in ten minutes. Having the factory service manual would allow you to do it in the driveway. If you have access to any Cadillac service manual from that era, it will walk you thru it. The Allante just used a different attachment point.
    May 2013
    New Hampshire
    23
    Thanks so much carnut! i just bought my service manual on ebay, should be here next week Thanks again
    May 2013
    New Hampshire
    23
    I found out that my car was shifting hard because the engine was way underpowered due to 3 bad injectors. Just thought people might want to know.
    carnut likes this.
  7. Remove Advertisements
