Allante Restoration advice
Results 1 to 7 of 7
Cadillac Allante Forum Discussion, Allante Restoration advice in Past Cadillac Vehicle Discussion; I would like to hear from anyone with advice regarding engine replacement options for a 1990 Allante. To date, I've ...
    jackl1956's Avatar
    jackl1956 is offline Cadillac Owners Member
    Automobile(s): 1990 Allante
    Aug 2005
    Capistrano Beach, California
    27
    I would like to hear from anyone with advice regarding engine replacement options for a 1990 Allante. To date, I've spoken to Cadillac who will install a new? crate engine for approximately 7500, I've considered a Jasper remanufactured engine for about 4500 installed. In both cases a 3 year warranty comes with the installation. My car is not perfect and I intend to use it as a daily driver. That being said, I would choose a professional alternative with a company known to back their product. I would especially like to hear from anyone who has had similar repair work done with lasting results. Money, is certainly a consideration. Thanks Jack
    Allante North *'s Avatar
    Allante North * is offline Banned
    Automobile(s): 1993 Triple Black Allante
    Dec 2002
    Rocky Top Tennessee
    57
    701
    Re: Allante Restoration advice
    Jack,
    Have you considered re-building the one you have? Might be a less expensive alternative to a crate engine. What is wrong with your engine and where are you located?
    Don
    Bob Rich is offline Cadillac Owners Member
    Feb 2005
    56
    Unless you have built engines before, and have a lot of specialized tools and a stock of the consumables (sealers, cleaners, etc), you are better off reliability and price wise using a remanufactured engine from GM or one of the national rebuilders.
    jackl1956's Avatar
    Aug 2005
    27
    Don,
    My car is overheating.............is this a typical problem? So from a serviceability standpoint I am considering a crate engine to ensure a starting from a known quantity. I am located in San Juan Capistrano, California.
    Jack
    Feb 2005
    56
    Replace the radiator and see what happens. They are readily available and not too expensive.
    terrible one's Avatar
    terrible one is offline Banned
    Automobile(s): 1976 Eldorado project
    May 2005
    El Dorado, Arkansas
    26
    1,631
    Yeah, just because its overheating doesn't mean it's time for a new engine, or even a rebuild. Your radiator is probably clogged. Either get it roded, recored, or replaced. If that doesn't work, do it again, and flush the block.
    Allantesource is offline Cadillac Owners Fanatic
    West Palm Beach, FL.
    188
    In addition to a clogged radiator, cooling fan relays, cooling fan motors, loose/slipping water pump impellar, and thermostat all should be ruled out as the possible cause of your overheating. There are so many good used Allante' 4.5's around that I would not even consider getting a rebuilt one or a crate motor. The 4.5's appear to have a service life well in excess of 200k miles, with a few approaching or even beyond 300k.
  10. Remove Advertisements
