1992 4.5 radiator hoses
Results 1 to 11 of 11
Cadillac Allante Forum Discussion, 1992 4.5 radiator hoses in Past Cadillac Vehicle Discussion; My 92 radiator sprung a leak at the drivers side tank. I removed it and sent it to my favorite ...
    nbaum is offline Cadillac Owners Member
    Automobile(s): 1993 & 1992 Allante
    Oct 2013
    40
    My 92 radiator sprung a leak at the drivers side tank. I removed it and sent it to my favorite radiator repair shop.
    It occurred to me that this is a good time to replace the radiator hoses. Especially the lower one. Are these not available in the proper size and bend configuration? I can't seem to find any at the usual auto parts stores.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    They're most definitely svailable, probably my have to be ordered to the store though. Just check on www.rockAuto.com.
    carnut is online now Cadillac Owners Master
    Feb 2003
    california
    69
    6,640
    Re: 1992 4.5 radiator hoses
    Try www.allantesource.com Or Tom Rohner in Los Angeles. www.allantestore.com
    Oct 2013
    40
    Well I have bigger problems than just the hoses. The radiator cannot be repaired because it has plastic side tanks. The real problem is the low coolant sensor in the radiator is not duplicated on replacement radiators. What are people doing for replacement radiators on the 92's?
    jim e is offline Cadillac Owners Member
    Automobile(s): 1990.5 allante, 1990 allante
    Nov 2003
    AUBURN NY
    62
    54
    On my 1990 with 4.5 engine, I used a NAPA lower hose. It looked the same as original, except the NAPA one did not have the spring coil on the inside bend like the original did, so I just placed that spring inside the NAPA one and was all set.
    As far as radiator Best bet is to call Dick at allante source
    Oct 2013
    40
    Emailed Dick Hussey about the radiator. Seems there are no exact replacements for the 92 radiator(probably earlier Allante's as well). The difference is that the low coolant sensor on the Allante is a one wire front mounted sensor. The replacement radiators are really for later Cadillac's and are the same except they use a 3 wire rear mounted larger sensor. this of course will not work with the 92 Allante sensor. There are some radiators available with no sensor holes. I purchased one without sensor holes from Rock auto $118 plus $7 freight. Dick said to disable the message at the information center but I think what I will do is ground the sensor wire. Since its a one wire sensor I suspect that will simulate a full coolant tank thereby disabeling the error message.
    Nov 2003
    AUBURN NY
    62
    54
    Let us know if the grounding works with that wire to stop message, as most likely I will get to this at some time in the future, as both my allantes have orig radiators.Like anything else the age of these parts will deteriorate
    Feb 2003
    california
    69
    6,640
    On my 91 I found a radiator that had the plug for this sensor in rear. It was in an Eldorado. Moving the sensor to the rear was actually an improvement! Was easier to remove the radiator. I dont recall it having a different diameter bung to screw in the Allante sensor. It simply had a plug in it which I removed.
    Oct 2013
    40
    Back on hoses. I bought the upper hose from Allantesource. Dick told me the upper hose is unique to Allante 87 to 92 .I could not find the upper hose any place else. The lower hose is available at the usual local parts houses.
    Dick also told me the grounding of the sensor will work but he likes to turn off the message because he never has to worry about the wire coming loose. I think i will still ground off the wire. Its no worse than worrying that the wire will come off the sensor.
    Oct 2013
    40
    Well the 92 is back running. The grounding off of the coolant sensor worked fine. No error message. I expected some small leaks that had to be adjusted but there were none. Now I'am tackling the rattling cat converter.
    al1029 is offline Cadillac Owners Member
    Automobile(s): 92 allante
    Apr 2010
    3
    Quote Originally Posted by carnut View Post
    If he orders it from Tom He'll need a jar of Vaseline.
    I don't think it comes with the hose.
  14. Remove Advertisements
