89 transmission
Results 1 to 4 of 4
Cadillac Allante Forum Discussion, 89 transmission in Past Cadillac Vehicle Discussion; My 1989 Allante's transmission shifts ok into all gears but 3rd. The tac revs before it goes from 3rd to ...
    Bill Procuniar is offline Cadillac Owners Member
    Aug 2005
    1
    89 transmission
    My 1989 Allante's transmission shifts ok into all gears but 3rd. The tac revs before it goes from 3rd to 4th. Has any one had this problem or knows what may be wrong?
    Allantesource is offline Cadillac Owners Fanatic
    West Palm Beach, FL.
    188
    Re: 89 transmission
    Probably the clutch pack is worn, or else internal seals. The only thing I know of to try is to have the fluid and filter changed, and then add a container of Lucas transmission additive to see if that helps. But it's probably time for an overhaul.
    Feb 2003
    california
    69
    6,613
    Re: 89 transmission
    Always verify trans fluid full with engine at normal temp before any further diagnosis is attempted. If full, change the fluid, filter as recommended above and pray!
    dmowry is offline Cadillac Owners Member
    Jun 2005
    6
    Re: 89 transmission
    A word of caution. My mechanic tells me that, if the transmission fluid hasn't been changed for a while, to drop the pan and do a filter change first. After a thousand miles or so, then do the complete fluid change. His experience is that doing a change can often cause the transmission to go out. I had never heard this before, but it sure explains some of the transmissions I have replaced in the past.
  7. Remove Advertisements
