'89 ABS problem?
Results 1 to 3 of 3
Cadillac Allante Forum Discussion, '89 ABS problem? in Past Cadillac Vehicle Discussion; I'm working on an '89 Allante, and when you press the brake pedal, the DIC will have a message "Antilock ...
    caddydaddy's Avatar
    caddydaddy is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 Escalade 6.0L 2WD, 2007 Jeep Grand Cherokee Limited CRD
    Jan 2003
    Gales Ferry, CT
    35
    3,717
    Exclamation'89 ABS problem?
    I'm working on an '89 Allante, and when you press the brake pedal, the DIC will have a message "Antilock disabled" then about 5 seconds later it will say "Antilock ok". And it will do that each time you hit the brake pedal. There were no codes stored on the computer.
    Any ideas? :rolleyes2
    Thanks!
    Steve174 is offline Cadillac Owners Member
    Automobile(s): Allanté
    May 2003
    Boston, MA
    50
    20
    Re: '89 ABS problem?
    There is great guidance at Dick Hussy's site:
    www.allantesource.com
    Click on the ABS Info button and follow his advice.
    Steve
    Allantesource is offline Cadillac Owners Fanatic
    West Palm Beach, FL.
    188
    The three possible causes of your symptoms: nearly worn out brake pads, a weak accummulator, or worn out internal master cylinder seals. The "ABS Info" section on our website should guide you through evaluating the accumulator by counting the number stored pedal applications. Any questions, e-mail me. We have any parts you might need.
