can anyone tell why
Results 1 to 5 of 5
Cadillac Allante Forum Discussion, can anyone tell why in Past Cadillac Vehicle Discussion; just got the allante going over it can any one tell what cause's the dash lites to flicker every time ...
    silver haired fox is offline Cadillac Owners Member
    Automobile(s): allante
    Nov 2013
    ottawa canada
    64
    58
    can anyone tell why
    just got the allante going over it can any one tell what cause's the dash lites to flicker every time I touch he brake's thank's
    Feb 2003
    california
    69
    6,613
    Re: can anyone tell why
    I would inspect the engine grounds 1st. There at a bunch on the bolt holding the alternator on, as well as one just above the starter on the engine block. Theres one on the strut tower brace as well. Theres another below the alternator on one of the water pump bolts. The one on the water pump can be cut and a new eyelet installed so it too can be attached to the alternator bolt for easier access. Assuming all these points have been removed and cleaned and it still flickers, I would suspect an ABS pump drawing too many amps as it turns on. Each and every time you apply the brakes, the ABS supply pump turns on. I've also seen the alternator have a weak voltage regulator and cause this. To confirm, have a load test done on the alternator. Should produce close to 100 amps when loaded.
    Nov 2013
    ottawa canada
    64
    58
    thank's I'll check these out I was thinking would a dead battery cause this as well I think the last the last owner let the bat freeze i'm just boosting now to get it started
  5. #4
    Feb 2003
    california
    69
    6,613
    This car is VERY touchy regarding battery state of charge as well as alternator output. I would use a donor battery to see if the flickering quits. THEN.... buy a good battery. The Battery is the heart of this car!
  6. #5
    D Yaros's Avatar
    D Yaros is offline Cadillac Owners Fanatic
    Automobile(s): 1955 CDV, 1992 Allante, 1962 Olds 88 Conv
    Nov 2009
    Milwaukee
    176
    I can tell you that a bad connection at the battery will cause your symptom. That being so, it follows that a bad battery could also cause it.
  7. Remove Advertisements
