How to check codes in 1989?
Results 1 to 6 of 6
Cadillac Allante Forum Discussion, How to check codes in 1989? in Past Cadillac Vehicle Discussion; How do you access the codes on a '89 Allante? There is a problem with the ABS and the engine ...
    caddydaddy's Avatar
    caddydaddy is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 Escalade 6.0L 2WD, 2007 Jeep Grand Cherokee Limited CRD
    Jan 2003
    Gales Ferry, CT
    35
    3,717
    How do you access the codes on a '89 Allante? There is a problem with the ABS and the engine control computer.
    Steve174 is offline Cadillac Owners Member
    Automobile(s): Allanté
    May 2003
    Boston, MA
    49
    20
    Re: How to check codes in 1989?
    Press the "OFF" and "WARMER" buttons on the climate control panel. System will go into diagnostic mode and show and current and history codes.
    I have a 93 and the codes are definitely different than the 89. Here's a link to a site for a 91 code table. It shouldn't be too different for your 89:
    http://www.eldocountry.com/allante/diagnostics.html
    Steve
    Kev's Avatar
    Kev
    Kev is offline Cadillac Owners 10000+ Posts
    Automobile(s): 1989 Sedan DeVille is now just a fond memory ....
    Aug 2004
    Left Coast (Central)
    56
    10,420
    Allantesource is offline Cadillac Owners Fanatic
    West Palm Beach, FL.
    188
    If you need info on Allanté ABS system troubleshooting, we have a section on our website that may be helpful at www.allantesource.com . Look for the "ABS Info" section on the left menu buttons.
    Brix is offline Cadillac Owners Member
    Mar 2006
    19
    Would I use the same input for my 85 DeVille?
    Feb 2003
    california
    69
    6,626
    Yes, hold the off and warmer buttons at the same time. Continue to hold them until the climate display shows any codes. Be aware getting the codes is one thing, understanding and being able to fault trace them is quite another. I always reccomend having the Cadillac factory service manual to do this checking. knowing what each code refers to can help even the non mechanic relay info to the ultimate repairer and possibly speed up diagnostic time which could save money.
  9. Remove Advertisements
