Chane rear spark plugs
Results 1 to 3 of 3
Cadillac Allante Forum Discussion, Chane rear spark plugs in Past Cadillac Vehicle Discussion; How do I change the rear spark plugs next to the firewall ? I am sure there is some trick ...
    earld is offline Cadillac Owners Member
    Automobile(s): 1990 Allante
    Oct 2013
    Hickory NC
    70
    50
    How do I change the rear spark plugs next to the firewall ? I am sure there is some trick to it . Do I loosen the engine mounts or just what do I do? Thanks
    Feb 2003
    california
    69
    6,680
    Re: Chane rear spark plugs
    Most folks do it while the car's on a hoist with a ratchet and extensions. I've done it with removing the upper dog bone engine mount, then loosening the front 2 engine cradle mounts and lowering the engine slightly. As the engine lowers it tilts forward. I used DELCO platinum plugs for a newer 4.9 V/8 Cadillac. Be aware you will more than likely damage the plug wires so have a set of DELCO wires available!
    Oct 2013
    Hickory NC
    70
    50
    I'm changing them too . I don't know when they were last changed so may as well do it now.
