instructions to remove the tower
Results 1 to 6 of 6
Cadillac Allante Forum Discussion, instructions to remove the tower in Past Cadillac Vehicle Discussion; I have looked but ,not in the right spot for instructions for removing the info tower. I don't want to ...
    earld is offline Cadillac Owners Member
    Automobile(s): 1990 Allante
    Oct 2013
    Hickory NC
    70
    50
    I have looked but ,not in the right spot for instructions for removing the info tower. I don't want to mess it up so if anyone knows how to do this let me know . My car has been sitting for years and the contacts must be gunked up because nothing will reset and I cant get things to work as they should. Any info appreciated.
    Feb 2003
    california
    69
    6,680
    Re: instructions to remove the tower
    Remove top center A/C vent using a dull butter knife on either side to release pins. Remove screws in behind vent. Try to pull it out. If its still secure, there are 2 10MM? nuts holding the bottom of it where it meets the center console. To gain access you remove the under dash panel below steering wheel and look in behind the tower. Find a small child to get in there with a 1/4 inch ratchet and socket or open end wrench to remove them. Slide out D.I.C Most mechanic's don't reinstall the bottom nuts on reassembly.
    Oct 2013
    Hickory NC
    70
    50
    Thanks
    nbaum is offline Cadillac Owners Member
    Automobile(s): 1993 & 1992 Allante
    Oct 2013
    40
    The service manual has pretty good instruction on how to remove the tower. Its just spread over the different components that need to be removed. The first thing to do is put your fingers in the tape slot at the bottom and pull out. If its loose you only need to remove the top vent and two screws.
    If you need to remove the two lower bolts I used my 3/8' drive air ratchet. The problem is that there is no room to get much movement on the bolt with a tool. The air ratchet solves that problem. DO NOT PUT THE LOWER BOLTS BACK IN ONCE REMOVED. The tower has to come out all too often to deal with the two lower bolts again and the tower sits in there quite well without them.
    Gregnyc1804 Guest
    . been trying to get this thing out for an hour now. Cant seem to get to the bottom screws. I cant even see them
    kiwigram is offline Cadillac Owners Member
    Automobile(s): '92 Allante, '93 Allante
    Nov 2007
    New Zealand
    76
    Firstly take down the hush panel from under the dash. Then you will need to remove the hush panel from beside the park brake pedal. Remove the hood release lever. Then on the right side of the footwell, remove the small panel that runs beside the accelerator pedal. Now remove the four bolts, two each side, and two screws at the "rear of the panel", and lower the knee bolster. You will then be able to see/access the two 10mm hex bolts right under the tower.
  9. Remove Advertisements
