Brake caliper piston won't screw in all the way!
Results 1 to 3 of 3
Cadillac Allante Forum Discussion, Brake caliper piston won't screw in all the way! in Past Cadillac Vehicle Discussion; I'm changing the rear brakes on a friends '89 Allante. It has screw in type pistons on the calipers. I ...
    caddydaddy's Avatar
    caddydaddy is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 Escalade 6.0L 2WD, 2007 Jeep Grand Cherokee Limited CRD
    Jan 2003
    Gales Ferry, CT
    35
    3,717
    QuestionBrake caliper piston won't screw in all the way!
    I'm changing the rear brakes on a friends '89 Allante. It has screw in type pistons on the calipers. I can't get the pistons to screw in all the way. They both go to a point, and just keep turning. Both pistons stick out over 3/4 inch from the caliper base. So there is enough room to get the pads on, but not enough room to get them over the rotor!
    Am I missing something, or any ideas on how to get the pistons to go in further? Is is possible the brake pads are incorrect? Should the piston be flush with the caliper base, like the pistons would be on the front calipers?
    El Dobro's Avatar
    El Dobro is offline Cadillac Owners Connoisseur
    Sep 2003
    1,471
    Re: Brake caliper piston won't screw in all the way!
    There may be internal corrosion keeping the piston from bottoming out. You might be better off swapping them out for a set of reman calipers.
    caddydaddy's Avatar
    Jan 2003
    Gales Ferry, CT
    35
    3,717
    Thanks! Would it help to push the piston down with force, or will that not do anything? It just seems wierd that they both go down to a point, then just spin!
    I've never had a problem with these before like this.
