Radio woes - Page 2
Results 16 to 30 of 39
Cadillac Allante Forum Discussion, Radio woes in Past Cadillac Vehicle Discussion; here are some pics of the real speaker and the amp, as well as an amp and speaker from a ...
  1. #16
    cadmat's Avatar
    cadmat is offline Cadillac Owners Fanatic
    Automobile(s): 1988 Allante.
    Feb 2005
    vista, california
    189
    Re: Radio woes
    here are some pics of the real speaker and the amp, as well as an amp and speaker from a sevilee and the door speaker from a 92 Eldorado, as you can see the speaker enclosures are designed specifically for each car that they are installed in, so a speaker from the eldorado, does not fit directly into the door of the Allante. However, the speaker and amp will transfer between the two enclosures relatively easily.
    here is the Allante speaker enclosure opened up, notice the metal box directly below the speaker itself, about the size and thickness of a deck of playing cards, this is the Bose Amp.
    Here is a 1992(ish) Eldorado Front Door Bose Speaker Assembly, notice it is quite a bit larger but the speaker itself as well as the amp inside are the same size as the Allante.
    Here is a Bose Amp and Speaker out of a early 90's Sevile ( going by memory here) again, the amp is basically the same, only the speaker and assembly is different.
    And here we have the Amp itself, when removed from the metal casing ( just 4 tiny screws, easy disassemble)
    I hope this visual helps clarify the process a bit.
    Matt
  2. #17
    earld is offline Cadillac Owners Member
    Automobile(s): 1990 Allante
    Oct 2013
    Hickory NC
    70
    50
    Re: Radio woes
    Thanks Matt, But why are the speakers required with amps? What does an ampless speaker do to the system?
  3. #18
    Feb 2003
    california
    69
    6,643
    Re: Radio woes
    The radio has no amp built in! So no output of audio. It is a pre amp radio. Regarding swapping amps from another car, read the decal on the amp. It will say which side of the car and whether it goes front or rear. I got mine from a Corvette. Approx the same interior volume (size) so the sound wasn't altered. Notice the second to last picture, the harness plugs into the amp. In the last picture, the wiring is soldered to the amp. Allante's use the plug in style amp which makes it easy to upgrade.
  5. #19
    Oct 2013
    Hickory NC
    70
    50
    Re: Radio woes
    I found a set of 99 Eldorado speakers and a set of 90s Seville speakers very cheap . Both guarantee them to work but who knows. Less than 75 bucks for two. That a good deal?
  6. #20
    Oct 2013
    Hickory NC
    70
    50
    Re: Radio woes
    <a href="http://s1231.photobucket.com/user/55birdman/media/sevilleamp.jpg.html" target="_blank"><img src="http://i1231.photobucket.com/albums/ee501/55birdman/sevilleamp.jpg" border="0" alt=" photo sevilleamp.jpg"/></a>
    Don't know if tis will work but this is a pic of one set of speakers
  7. #21
    Feb 2003
    california
    69
    6,643
    Re: Radio woes
    The speakers themselves rarely fail. The amps do but, again, to have 4 failed amps is highly unlikely! Yes the display will show on the tower with no radio audio. Again, is there power to the radio receiver behind the glove box?
  8. #22
    Oct 2013
    Hickory NC
    70
    50
    Re: Radio woes
    I have power to the receiver .
  9. #23
    cadmat's Avatar
    Feb 2005
    vista, california
    189
    Re: Radio woes
    Power to receiver is only part of the equation, you need to confirm power to the speaker Amps..
  10. #24
    Oct 2013
    Hickory NC
    70
    50
    Re: Radio woes
    Tomorrow the weather is supposed to be decent. I will check out the speakers and post my findings.
  11. #25
    Oct 2013
    Hickory NC
    70
    50
    Re: Radio woes
    Speakers all work . I found someone that can check the amps or so he says. Ill let you know when I find out whats up.
  12. #26
    silver haired fox is offline Cadillac Owners Member
    Automobile(s): allante
    Nov 2013
    ottawa canada
    64
    58
    Re: Radio woes
    I just got a 1989 allante and having the same problem but every once and a while i'll get sound from a station then it go's any i9dea's on this thank's
  13. #27
    Oct 2013
    Hickory NC
    70
    50
    Re: Radio woes
    I just sent mine to Dick Hussey to check out.
  14. #28
    Oct 2013
    Hickory NC
    70
    50
    Re: Radio woes
    Receiver was bad . Dick repaired it and its on its way back . Will be delivered tomorrow. Should have it operational before dark. Then it goes up for sale
  15. #29
    cadmat's Avatar
    Feb 2005
    vista, california
    189
    Re: Radio woes
    what goes up for sale, the car or the reciever?
  16. #30
    Oct 2013
    Hickory NC
    70
    50
    Re: Radio woes
    The car
  17. Remove Advertisements
