Transmission Shift solenoids
Results 1 to 2 of 2
Cadillac Allante Forum Discussion, Transmission Shift solenoids in Past Cadillac Vehicle Discussion; I'm trying to diagnose problems with shift 3rd to 4th. Interment problem; car seems to shift normally up to 3rd ...
    Charade@msn.com is offline Cadillac Owners Member
    Automobile(s): '92 Allante & '98 Catera
    Nov 2006
    Indiana/Florida
    5
    I'm trying to diagnose problems with shift 3rd to 4th. Interment problem; car seems to shift normally up to 3rd gear, then sometimes it does not shift into 4th, or stays in 3rd gear. Anybody have experience diagnosing the 3-4 shift solenoid, and/or the lockup solenoid (VCC). I suspect possible electrical connection problem either outside or inside the transmission?
    Automobile(s): 1999 BMW 740 Il. 2005 Jag XK8, 1988 Mercedes Benz 300 SE
    Feb 2003
    california
    69
    6,689
    Re: Transmission Shift solenoids
    First have a trans shop verify the TV cable is adjusted to spec. A too short cable will cause delayed shifts. Should take 1/2 hr to adjust and road test.
