Delay wipers inop
Results 1 to 2 of 2
Cadillac Allante Forum Discussion, Delay wipers inop in Past Cadillac Vehicle Discussion; My delay wipers do not work. The wipers however function properly in lo and hi positions, and the mist function ...
    iandeville's Avatar
    iandeville is offline Cadillac Owners Member
    Feb 2005
    salt lake city, utah
    Delay wipers inop
    My delay wipers do not work. The wipers however function properly in lo and hi positions, and the mist function also works. With the wipers on in either lo or hi if the switch is moved to a delay position the wipers just stop in the middle of the windsheild, but when moved to the off position they park as they should.
    Please help!
    Ian
    El Dobro's Avatar
    El Dobro is offline Cadillac Owners Connoisseur
    Sep 2003
    1,471
    Re: Delay wipers inop
    Since the wiper switch is very expensive, I took mine apart and did a tune-up on it. Everything worked fine after that. Luckily for me, it was the switch that was the problem. If it's not the wiper switch, it could be the wiper motor cover, which contains the board that delays the wiper motor.
