Results 1 to 3 of 3
Thread: Help Please, 93 Allante Codes
    tedasaurus is offline Cadillac Owners Fanatic
    Automobile(s): 1981 Fleetwood, 1994 Fleetwood
    Jul 2004
    Dallas, TX
    42
    129
    Just bought a '93 Allante with 50k miles. Like it. Has two fault codes showing thru the DIC.
    1. Shorted fuel pump circuit (code P019)
    2. RSS resistor module short to ground / open (code S055)
    Ride stays soft at any speed so I imagine the shocks aren't adjusting. Car runs perfect with no issues at all. What options do I have? Your help is very appreciated.
    Automobile(s): 1999 BMW 740 Il. 2005 Jag XK8, 1988 Mercedes Benz 300 SE
    Feb 2003
    california
    69
    6,688
    Re: Help Please, 93 Allante Codes
    You have to know whether these are "history" or current codes. I will assume the fuel pump code is history and the RSS is current. You must have the factory service manual if you own an Allante and want to work on it! The RSS code affects the ride adjustments as driven. The module is either faulty or the wiring to it needs diagnosed. Cannt do without the manual. Is the wire connector plugged in at the spare tire? That's unplugged when the car is smog tested and can be left unplugged.
    Jul 2004
    Dallas, TX
    42
    129
    I could not find a plug near the spare tire. I will buy a service manual. The only code current is the Shorted fuel pump circuit. Of course the damn car runs perfect. Lol.
  • You may not post replies
