Tranny woes
Results 1 to 10 of 10
Cadillac Allante Forum Discussion, Tranny woes in Past Cadillac Vehicle Discussion; Today I noticed that Aurora started shifting from 2nd to 3rd later than normal. Upchange could be helped by releasing ...
    Johnny_Buchanan's Avatar
    Johnny_Buchanan is offline Cadillac Owners Fanatic
    Automobile(s): Allante '88
    Jun 2009
    Finland
    51
    143
    Tranny woes
    Today I noticed that Aurora started shifting from 2nd to 3rd later than normal. Upchange could be helped by releasing gas pedal a bit. Upon arriving home I immediatelly checked fluid level and found it wanting It took appr. 0,7 litres to bring the level to max (according the stick 0,4 is the amount needed from low to full).
    On test drive it still seemed to be changing at higher rpm than previously.
    Fluid did not smell burned and colour was normal.
    So, have I cooked it? Is this something others have faced? Sign of tranny failing for good?
    -J
    Sent from AutoGuide.com Free App
    Feb 2003
    california
    69
    6,664
    Re: Tranny woes
    1st, why are you asking about an Aurora in a Allante forum? 2nd, if an Aurora has a TV cable then I would suspect it as being adjusted too short. Given what you've said it sounds like an external issue, not a failing trans.
    Jun 2009
    Finland
    51
    143
    Re: Tranny woes
    My bad on not being clear, Aurora is the name of the '88 Allante listed on my profile
    -J
    Feb 2003
    california
    69
    6,664
    Re: Tranny woes
    Thanks! I still think you have a TV cable issue. They can bind or slip out of adjustment where it anchors to the throttle body.
    Jun 2009
    Finland
    51
    143
    Carnut,
    Thank you for your help! Now, a Q from total newbie when it comes to slushboxes: how do I verify and if needed, adjust this TV cable?
    -J
    Feb 2003
    california
    69
    6,664
    Re: Tranny woes
    Hard to do via the printed word. A black cable comes from the transmission up to the throttle arm. As the throttle is moved this cable is pulled to alter the shifting points. Where it attaches at the throttle pivot there is a silver D shaped button on the cable. Using a screwdriver, press down firmly on this button. While holding it down slide the threaded black plastic cable housing back towards it. You will see serrations on the black cable much like threads on a bolt. Retract this cable till no threads show. Then release the button. With the engine off, rotate, by hand, the throttle to wide open. As you rotate the throttle, the cable will extend to its correct length. There will be resistance from the cable because its attached to a return spring of sorts in the transmission. Just make sure you go to fully wide open. It will make a plastic ratcheting sound as the threads slip past the cable housing. Now drive the car and report back. This cable if adjusted too short, raises the shift points, adjusted too long, it will shift too early and soft.
    Jun 2009
    Finland
    51
    143
    Carnut,
    Thank you for very clear instructions!
    I do owe you a pint!!
    However, when looking under the bonnet, this is what I have:ImageUploadedByAG Free1379164953.031028.jpg
    Under the narrower black cover is normal wire going to d-shaped thingy.
    Only narrations that I can see are here:ImageUploadedByAG Free1379165103.062327.jpg
    and they seem to be part of the cable cover.
    Obviously, I'm missing something here!
    -J
    Feb 2003
    california
    69
    6,664
    Re: Tranny woes
    "Serrations". Go to any trans shop and they can adjust the TV cable in about 5 minutes. I said it was hard to explain but simple to do
    Jun 2009
    Finland
    51
    143
    Again, thank you for your advice!
    However, solving this problem will have to wait for next spring. Autumn is here and I took Aurora to winter storage today.
    -J
    Feb 2003
    california
    69
    6,664
    Re: Tranny woes
    Its down to 83 F today. Washed my car and turned down the A/C !!!!
  13. Remove Advertisements
