93 allante relay locations
Results 1 to 3 of 3
Cadillac Allante Forum Discussion, 93 allante relay locations in Past Cadillac Vehicle Discussion; I need some help locating some relays within the car..... this car is a mess....... crash rebuild is how it ...
    mike11 is offline Cadillac Owners Member
    Sep 2013
    1
    I need some help locating some relays within the car..... this car is a mess....... crash rebuild is how it was bought..... it was half put together it looks.....
    heres where i am car sill start on ether but has no fuel , pump does not come on with the key......
    I can not find the inertia switch anywhere in the car to reset, if i at least knew which color wires went to it and where it was I could bypass it to get the car to move, next is of all the fuse/relay blocks in the car which one has the fuel pump relay in it??? and which one is it??? all the lids for them along with the manual are missing. If I could at least find the FP relay I could again make the pump run n get this thing to move so I can get deeper into putting it back together.....
    Thanks
    Automobile(s): 1999 BMW 740 Il. 2005 Jag XK8, 1988 Mercedes Benz 300 SE
    Feb 2003
    california
    69
    6,689
    Re: 93 allante relay locations
    Buy the factory service manual! I wouldn't even attempt to reassemble this car without one. Call allantesource.com in Florida and ask Mr Hussey about an enertia switch.
    D Yaros's Avatar
    D Yaros is offline Cadillac Owners Fanatic
    Automobile(s): 1955 CDV, 1992 Allante, 1962 Olds 88 Conv
    Nov 2009
    Milwaukee
    182
    As the man said; BUY THE FSM! You are wandering around in the dark, with one hand tied behind your back without it!
