Does check engine light come on when you turn key on? Failed smog... please help!
Results 1 to 4 of 4
Cadillac Allante Forum Discussion, Does check engine light come on when you turn key on? Failed smog... please help! in Past Cadillac Vehicle Discussion; I failed smog today because the check engine light does not come on when I turn the key to the ...
    detourbeach is offline Cadillac Owners Member
    Automobile(s): 93 allante
    Aug 2013
    1
    I failed smog today because the check engine light does not come on when I turn the key to the "ON" position. The tech confirmed the light bulb was good because he disconnected the EGR and the light then came on.
    Can anyone please confirm this for me? Just turn your key to the ON position and see if the check engine light is supposed to illuminate. I think it is the very top light on the center of the gauge cluster. Thanks!!
    carnut is online now Cadillac Owners Master
    Automobile(s): 1999 BMW 740 Il. 2005 Jag XK8, 1988 Mercedes Benz 300 SE
    Feb 2003
    california
    69
    6,688
    Re: Does check engine light come on when you turn key on? Failed smog... please help
    If I remember correctly, this car has a "service engine now" orange light and a "service engine soon" orange light, not a "check engine" light. Turning the key to run, engine off, should cause both lights to illuminate. They should go off and remain off once the car is running. Disconnecting the EGR should cause one of those lights to come on. Reconnecting the EGR will keep the light off, car running but will hold a history code in diagnostics for a failed EGR circuit. I just looked at a cluster for sale on EBAY and these 2 lights seem to be in the center of the cluster at the top.
    smwalker is offline Cadillac Owners Member
    Mar 2005
    4
    Detour did you ever get this worked out? I am having the same problem. The bulb in mine is good as well as I can get it to illuminate briefly by cycling the key on and off a few times. But when I do I seem to flood the vehicle and it does not start up right away. Wondering what work around you found. And I am referring to the "service engine soon" light at the top center of the gauge cluster.
    Thanks for any info.
    Mar 2005
    4
    For future generations having this same problem the solution for the Allante (and all 1993 Cadillacs I suppose) is to go into diagnostic mode on the DIC and the "service Engine Soon" light illuminates. Then start the car and it goes off.
    Instructions for Diagnostic mode here:
    http://www.allantesource.com/rundiag.htm
    Talked with a smog tech here:
    http://stop-the-star-program.3084.x6....html#a5023885
  7. Remove Advertisements
