Anyone know where the low coolant sensor is located?
Results 1 to 6 of 6
Cadillac Allante Forum Discussion, Anyone know where the low coolant sensor is located? in Past Cadillac Vehicle Discussion; Does anyone know where the low coolant sensor located on a 1988 Allante, in the Radiator, or overflow tank? Any ...
    tjk5405 is offline Cadillac Owners Member
    Automobile(s): Allante
    Jun 2013
    8
    Any help would be greatly appreciated!
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    Low in the reservoir.
    jim55 is offline Cadillac Owners Member
    Automobile(s): 1987 cadillac allante
    Nov 2011
    Mead WA
    66
    15
    Re: Anyone know where the low coolant sensor is located?
    It is on the left-hand side of the radiator in front about three or 4 inches down
    cadmat's Avatar
    cadmat is offline Cadillac Owners Fanatic
    Automobile(s): 1988 Allante.
    Feb 2005
    vista, california
    189
    It is in the radiator, but not all of them have it, when I replaced the radiator in my 88 last year, I was never able to find a replacement with the provision for the sensor, so I had to install the new one with out it, and the low coolant message can't be turned off on the dash in the phase ones (AFAIK)
    Matt
    nbaum is offline Cadillac Owners Member
    Automobile(s): 1993 & 1992 Allante
    Oct 2013
    40
    On a 93 I once owned I had to replace the BCM or the PCM (can't remember which right now) to get the low coolant message to stop.
    BigJimmy is offline Cadillac Owners Member
    Automobile(s): 1989 Allante, 2014 XTS
    Oct 2016
    57
    1
    Low coolant sensor message - no problem. We resolved it on our 1989 today. The radiator in the car must have been replaced, because there was no insert for the sensor in the radiator. After inspecting the sensor, I noticed that there was only one line going to it. Because the end of the sensor was supposed to be in the radiator in contact with fluid, we decided that the lead to the sensor was positive and that the sensor completed the circuit when in touch with radiator fluid. I removed the sensor from the line and grounded it. The message goes away. Should be no big problem, as the engine temperature should skyrocket and cause many warnings if the radiator ever gets low on fluid.
  9. Remove Advertisements
